| Home > Help Needed / General Tech Chat > unleaded heads? | |||||||
16th Aug, 2004 at 12:04:07am
this is probably a stupid question but can someone give me an in depth run down on cylinder heads, do most of you have unleaded heads or do you have to keep using crappy four star, i understand you cannot use additives (redex) etc cos of the sodium valves or summat please explain. also why is it most of you dont go for larger bore engines 1380's etc most stick with a 1293 or similar, whats the best size bore and chamber size. bit puzzled hope sum1 can help :) |
16th Aug, 2004 at 08:15:35am
Modified head is what I run...
AlexF |
16th Aug, 2004 at 12:28:51pm
bore size, keep to a minimum
146 Posts Member #: 350 Turboing minis since '89 Supercharging minis since '04 |
16th Aug, 2004 at 10:03:05pm
its a safer bet to build a small cc but stronger engine then run more boost, than a big bore - with more flex in the block - at lower boost there will always be exceptions but this is the basic reason
17th Aug, 2004 at 09:29:21am
i also use the castrol valvemaster, for the pure reason its the only one i can find in local shops! Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
17th Aug, 2004 at 10:47:17am
valvenmaster worked in my camper van (1.6 air cooled) for thousands of miles without a problem!
AlexF |
20th Aug, 2004 at 01:31:09am
cheers guys helped a lot, if i buy a modified head can i get anunleaded one? |
20th Aug, 2004 at 05:01:45pm
yes you can Gav, aslong as you don't go for huge valves.
