Home > Help Needed / General Tech Chat > i have a 998cc turbo na engine. do i have to change dizzy for turbo or just timing
eskynation
Member #: 3490
new zealand. land of the kiwi bird
what tricks are there. just want to know on behalf of a freind. would i have to change dizzy or just timing... or convert to electronic ignition..
na turbo engine sounds super different! dont think ive ever seen one of them before!
i asume you had nothing to do with this?
as it seems yourcovering ground youve already been over...???
''1100cc mini na turbo engine sidemount turbo
94bhp@wheels at 7psi
86ft/lbs torque..''
eskynation
Member #: 3490
well im duin it on behalf of a freind. he wants to see what anyone else got to say other then me so yerr...
id be asking the same question
Ben H
Member #: 184
Melton Mowbray, Pie Country
So what have you advised? What do you have on your 1100?
The real answer is get mapped ignition. The cheep answer is lock the dizzy at a set set advance, i.e stop the weights or vacuum working this is rubbish though.
http://www.twin-turbo.co.uk
