| Home > Help Needed / General Tech Chat > brake problem | |||||||
25th Aug, 2008 at 05:20:04pm
I have a fair amount of travel in the pedal and pumping it won't bring it up, tried and tried at bleeding just in case there is a little air left but always the same. the brakes work ok, just that i'm not used to a long pedal travel myself, is there a way to adjust it?. btw, i'm running a servo, it seems to happen when i keep my foot on the brake and start the engine, i can feel the pedal drop as the servo kicks in, it stays that way until i switch off. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
25th Aug, 2008 at 07:35:01pm
sounds about right for a servo. |
25th Aug, 2008 at 08:40:56pm
what does it feel like without the engine running? Edited by Carl on 25th Aug, 2008. no longer a series, but still 1.3 turbo.
25th Aug, 2008 at 10:42:29pm
pretty rock hard, wont pump up either, just drops when the engine runs, feels a little scary with that much travel. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
25th Aug, 2008 at 10:56:23pm
any chance of a vacuum leak to the servo then? it all sounds like its working ok but is giving abit more travel than normal??
25th Aug, 2008 at 10:57:05pm
On 25th Aug, 2008 chinlesswonder said:
pretty rock hard, wont pump up either, just drops when the engine runs, feels a little scary with that much travel. yep thats what about right for a servo
pump up the peddle then fire her up whilst holding foot on peddle, if the peddle drops right down it does 2 things: 1.)shows the servo is working 2.)scares the crap out of you
Edited by Brett on 25th Aug, 2008. Yes i moved to the darkside |
25th Aug, 2008 at 11:06:35pm
pump up the peddle then fire her up whilst holding foot on peddle, if the peddle drops right down it does 2 things: 1.)shows the servo is working 2.)scares the crap out of you ![]() lol, thats exactly what it does, although what james says has got me thinking, i have minisport alloy 4 pot calipers on front and i think standard rear cylinders, i recall reading somewhere they have to be changed for smaller ones??? Edited by chinlesswonder on 25th Aug, 2008. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
25th Aug, 2008 at 11:21:31pm
you could have just got it mate.
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
26th Aug, 2008 at 01:40:12pm
This happened to me as well mate.
26th Aug, 2008 at 09:43:58pm
I was looking at that Richard, wasn't too sure if i should tamper with it too much in case i buggered up the servo,will give it a try tomorrow and report back. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
31st Aug, 2008 at 08:55:55pm
sorted, thanks Richard, worked a treat. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
1st Sep, 2008 at 12:45:38pm
Muckin Fagic.
