Home > General Chat > my seats are finally in!!!
speedster turbo
Member #: 244
Only took me a year from taking the originals out to putting a pair of RS turbo Recaros in!! followed advice and made my own subframes - works great, cheers Turbo Dave! Still plenty to do though, had to take my wiring loom back out on Sunday, I switched the side lights on (not that there are any installed on the car) and smoke came wafting gently out of the loom!! Turned out the feed from the light switch to the fuse box which runs the side lights (normally an in line fuse) must have shorted to ground somewhere. Took the opportunity to remove the wiring from the ballast ignition, washer pump and windscreen wipers. Also moved the feeds for the rear loom to inside the car along with the feeds for the side repeaters as I am gonna be running indicators in my mirrors.
Still got some major bodywork mods to do, fitting the BMW mini rear clusters and high(ish) level brake light along with an un-decided body kit, Fortek or Cos. and replacing 2 door skins.
Should be ready for next summer at this rate :cool:
Speedster turbo under construction
nutter driver
Member #: 47
Not very sunny swanage
ready for next summer, hmm, still probably be done before mine!! sat in pieces in the drive at the moment, seems to be a never ending challange.....
speedster turbo
Member #: 244
tell me about it, the engine was in and running 4 months ago! also doing my girlfriends XR2i, rebuilt engine, doing bodywork, fitting huge mad kit, etc, etc. Want to spend time on mini but..... fortunately, the mini is in my garage so there is no rush, good job too with no roof!
evolotion
Member #: 83
Glasgow, Scotland
check your number plate light bulet conectors, i had this problem, cause the previous owner of a mini i bought had conected them up the wrong way round!
Denis O'Brien.
