| Home > Help Needed / General Tech Chat > mega jolt lite junior | |||||||
969 Posts Member #: 47 Post Whore Not very sunny swanage |
16th Aug, 2004 at 10:52:25pm
just read an article in retro cars about a fully mapable ditributerless ignition system called mega jolt. anybody on here used it? the chap developed it for his turbo mr2 so i would imagine it would be ok for using on a mini turbo. i am seriously considering buying one of these kits, they reckon you can put it together and get it working for ?120ish quid, but ive got a mate who works in a garage, so i get free picking through the crashed cars that come in, so ireckon i can do it for more like ?50-60, just wondering if there is any obvios reason why it wouldnt work?? And on the 7th day........... God created turbochargers! |
17th Aug, 2004 at 12:04:06am
matt over at 16vminiclub has experience with mega squirt, so may be worth asking him? I wil be considering it too if/when i ever get around to turbo-ing! turbo 16v k-series 11.9@118.9 :)
17th Aug, 2004 at 06:08:33am
I'm sure when my bro reads this he'll put a post up. As far as I know this is the system he has fitted on his NA mini; but it is soon to be fitted to our hillclimb turbo mini.
17th Aug, 2004 at 08:35:18am
Mega jolt could be used no problem and is a reasonable mapable ignition system. It gives you a good number of load sites to create a decent ignition map from (100 I think)
http://www.twin-turbo.co.uk
244 Posts Member #: 34 Senior Member |
17th Aug, 2004 at 04:34:16pm
Looks good, might just give this ago myself!
17th Aug, 2004 at 05:56:00pm
acccording the the article in retro cars, its seems that you can weld a sierra sensor ring off the crankshaft pulley, then position the sensor in the handilly provided slot on the timing chain cover.
18th Aug, 2004 at 08:40:58am
Well I'm not going to rewrite all that has been written on megasquirt, but here is what I know and some links to where I found it all out.
![]() 111 Posts Member #: 265 Advanced Member Southampton |
18th Aug, 2004 at 09:01:04am
18th Aug, 2004 at 09:56:28am
thanks a lot guys, much appreciated! And on the 7th day........... God created turbochargers! |
46 Posts Member #: 351 Member |
18th Aug, 2004 at 12:25:42pm
I'd like to know when the "real" megajolt will be finished.
French turbocharged 998cc |
24th Sep, 2004 at 05:37:58pm
It's around 5 weeks since I first read this post, and today I completed my Mega Jolt instalation!!!
25th Sep, 2004 at 10:44:24am
The man Vizard recommends that a non turbo engine needs around 35 degrees total advance and for every PSI of boost this should be retarded by 1.1 degrees (so at 10psi you should be running around 24 degrees total advance). I think that if you stick to around 20 to 24 degrees total advance you should be safe to drive and have a play.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
18th Jan, 2009 at 10:01:39pm
Wow thanks for this just what I was looking for a 10x10 load bins
On 18th Aug, 2004 Ben H said:
Well I'm not going to rewrite all that has been written on megasquirt, but here is what I know and some links to where I found it all out. Firstly the crank sensor. I got one off the front of a sierra and the sensor to go with it. I have mounted it using the crank pully off a mini that has the big weighty bit on, I got it turned down to suit and stuck it on with some glue. I might be adding a grub screw to it at some point, to fix it more securely. See the picture below for how I mounted the crank sensor. It is a bit of a trial at the moment so looks a bit rough: http://members.lycos.co.uk/hamerhamerracin...bimg/Wheel1.JPG Load site: Not sure if I am using the correct term, but basically the ignition advance is calculated from a matrix of RPM verses MAP (Manifold Air Pressure). The mega jolt has a 10x10 matrix and the megasquirt has a 7x7 matrix. Obviously the bigger the matrix the more accurately and better the engine can be tuned. EDIS is a ford ignition controlled to find out how it works check out: http://www.bgsoflex.com/mjl/mjl_edis_summary.html There is not a huge difference between the two kits, I personally would go for megasquirt as it has been around much longer and most bugs have been fixed, the megajolt is still quite new. There are no major differences between any of the ignition controllers on the market. They all control ignition and they all work fine, more or less. Obviously you have to build it yourself and there is no warranty with it. For lots more information on megasquirt: http://www.megasquirt.info/index.html I would definitely recommend it for any turbo engine for all the reasons you mention plus improved economy. I run a supercharger and I don't care the TB is on the wrong side.
