Home > Wanted > alloy rad and polycarbonate windows
turbo22
Member #: 3684
wisborough green west sussex
i need alloy rad,poly windows,braided fuel line,suitible fuel pump for hi spec turbo setup,harneses,split rim wheels,a dash,wiring loom the list goes on!!!
cheers pete
Split rims Talk to FastCarl or go on his site
Search for Force Racing on google and its the foxwebsite one (cant remember it exactly.
Ally rad There has been a recent post about one on ebay all day today. in that post there is a recomendation of one so i would suggest google search on that aswell.
Poly windows have a search on here as there have been companies talked about pretty regularly.
Braided feul line: search on here for feul lines and see what others do and were they get it from. Pretty sure that when most do it they run Copper lines and then only braided where they need to be.
Metro Turbo Feul pump will see you find, ebay that begger unless someone has one on here, dont forget that you will need the Rising Rate Feul Pressure Regulator.
Google for your harnesses.
Dash there are many options, Curley, tdk amoungst many others
Wiring loom i would most probably suggest minispares or the like as at least then you know theres not going to be a load of bodges you need to sort out on it.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
TRS harness is good value for money
On 19th Jan, 2010 wil_h said:
turbo22
Member #: 3684
cheers for the help!!!
turbominij
Member #: 2104
Essex - UK
verdict on the ebay alloy rad is to run a mile and go to radtec far better quality (aparently)
or just get the mini spares 2 core rad(not alloy)
http://www.radtec.co.uk/index.php?p0=product&cpid=12&cid=52
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
lockfast
Member #: 2775
Aberdeen
I will soon have a minispares 2 core rad up for grabs if that is any use? I am fitting a front mounted rad over the winter.
t3gav
Member #: 229
Gavin@minispares.com
kent
Phil C has a MPI tank and pump for sale too.
