Home > Help Needed / General Tech Chat > Costing up a turbo conversion
Neil8p
Member #: 65
South Yorkshire
I need saving from this normally aspirated nightmare I live in :) so can anyone help with rough costs so I can plan out my spend?
I've found a standard MG metro engine which will be be stripped, checked and rebuilt, so I'm thinking I need the following
Turbo head
Turbo pistons
Carb
Dizzy
T2 Turbo
Camshaft
mirage manifold
Exhaust
MPi Fuel tank complete with pump
Fuel regulator
What big/expensive bits have I missed, and what sort of costs am I looking at, either for new or s/h plus refurb costs?
Neil
the mg cam is the same as the turbo
mg head will be fine for the job
might have an very good spi tank i can sell as im getting an alloy one sorted this winter hopefully.
Might have got a carb too but not 100%
Also im thinking (but not sure yet) that i might be selling a nearly new T2 off a silvia
If you want to come over and take any pics your more than welcome, you can have a drive as well if you like as mines now up and running.
Neil8p
Member #: 65
South Yorkshire
Cheers, sounds like a plan :)
Let me know if you're about one evening next week and I'll pop over from work.
Gibbo
Member #: 34
I thought the Turbo cam was the same as normal metro's, and the MG one had a more sporty profile?
nutter driver
Member #: 47
Not very sunny swanage
gibbo is right iirc
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
you do remember correctly nutter
AlexF
Neil8p
Member #: 65
South Yorkshire
So, any ballpark costs?
Anyone?
Im away as of friday for 2 weeks neil but when i get back you can pop over after work no problem. Can give you an idea of costs as well as ive done a few *smiley*
Knew one metro cam was similar. Mg metro cam goes well in turbos though doesnt it? Think it was GF that said it did *smiley*
nutter driver
Member #: 47
to be fair, i have also heard that the mg cam is very good in a turbo, not tried it tho, one for the future methinks!
as for costs, if i remeber ill try and work out some of my figures later on, but now its lunch time....
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
heres a stab at it...
assuming you want a good 120-140 bhp
Turbo head - Morspeed stg 3 about £350
Turbo pistons - £200 plus about £50 for a rebore
Carb - new £250 or SH £20-40
Dizzy - any electronic metro dissy will do so £10-30
T2 Turbo - hmm tricky one £100 for an ebay snotter to £350 for an exhange rebuilt.
Camshaft - any spec is about £80 for a kit
mirage manifold - £350
Exhaust - depends on your taste £50-100
MPi Fuel tank complete with pump - its easier to modify a std tank! but a mpi one is about £80-100 I think.
Fuel regulator - New £38
so thats a total of £1473
EEEEKKKK!!
I spent 250 on an enigne all the bits to get it running, 350 on a head, 80 on an exh
so thats about 700odd for about 120bhp!!
alex
AlexF
nutter driver
Member #: 47
since alex has covered the propper costs, ill just tell you mine....
complete engine with gearbox and all ancilleries and spare turbo £145
fuel pump and fpr, free from a mate of mine who was breaking a r5t
turbo box and oil pump, £70
fuel pipe, £5
tank- £5 to get a brave/stupid mate to weld up
thats about it at the moment that i can think of, im sure there is alot more though. as a side note, my entire car has/is actually been built to a very good standard i want to get the engine in and running and driving before i decide what to do with everything, however i do occasionally have a bit of luck, so if it comes good then i may all be ok, if not, then ill strip and redo the engine!
Hth a little bit...
Pete
Neil8p
Member #: 65
South Yorkshire
Great, thanks for the help.
No mad rush so I can hopefully find some decent bits at reasonable prices.
