Home > Help Needed / General Tech Chat > Cooling Bulb.
FesterTurbo
Member #: 18
What do you guys think about this little toy?
http://www.demon-tweeks.co.uk/catalogue/pr...PCODE=DEI080110
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
yes it would lower ACTs...
yes its a huge restriction in your inlet system!
alex
AlexF
I like this, ideal for drag racer, my ACT are very low, but if they where not, I'd buy this
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
but its a huge resitrction!!
no to mention there is VERY little cooling surface area!
in a word USELESS!
alex
AlexF
Mirage
Member #: 119
Mmm interesting, i've seen a few of these.
Not to sure about the restriction. Looking at the diameter of the bomb it looks to be approx half the dia of the tube it sits in. Taking the 3" example and working out surface areas
tube has 7.07 sq"
bonb
Mirage
Member #: 119
tube has 7.07 sq" (3" tube)
bomb has 1.767 sq" (1.5" bomb)
Gives you a surface area to flow of 5.3 sq" as opposed to the 2.401 sq" of you 1.75" hif carb.
I cant remember the boiling point of CO2 buts its pretty cold (think its -40 degs cel) so you do get a large temp gradient that would pfset the fact that the surface area isn't so great to a certain extent.
Got to admit for all out power i can think of a much better approach.
Mirage
Member #: 119
P.S.
I like to try and avoid buying anything from tweeks as they are sooooooooooooooooo expensive.
NYAuthi
Member #: 150
Why not go another route and cool the intercooler with either some nitrous or even co2. Very simple, effective and alot cheaper than that setup. Also nothing in the way of your air charge! The most expensive part of this setup is a proper bottle to hold your compressed whatever. Other than that you would need some brake line and a high pressure solenoid and of course a switching device.
-james
