Home > Help Needed / General Tech Chat > needle?
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
new engine is in a finish state ,
and I'm start to look for a good needle specs to start with ,
phase 2 cam; 1310 ,8.5c/r; 10/12 psi daily with an adjustable 18 psi max for special days,
what are yours?
fab
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
start with a std one and grind it down!
alex
AlexF
minimark
Member #: 19
newcastle
angle grinder or die grinder????
nutter driver
Member #: 47
Not very sunny swanage
could use a coffee grinder?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
no no
floor grinder for concrete...
alex
AlexF
my needle is std, god knows why, but it works!
minimark
Member #: 19
newcastle
concete needles is that the long lost answer , that we have been looking for big power?????
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I dont know... I dont have big power LOL!!!!
alex
AlexF
true...
Don't know what to suggest Fab - do you have a lambda meter yet?
TurboHarry
Member #: 115
Austria, near Vienna
Hi Fab, I am using a std. BCA with green spring at the moment, wideband lambda says "very good" (means AFR 14,0 at cruise and 12,5-11,8 at full throttle); you know my engine combo!
Any progress in your wideband project?
Bimmer Twinky headed and turboed A-Series:
http://www.minifreunde.at/harry/projects.htm
fab
Member #: 100
Paris\' suburb
Hi fel's
I'll grind down mine slightly later,
the idea is to start with something approximative, as the wbo2 set up is not finished yet, and I'm only using a std afr sensor, which is not enough accurate.
the idea was to know what are using phase 2 cams guys . I'll start with something on the rich side as a bca one.
thanks
fab
Arno
Member #: 233
Beugen, Netherlands
How do you grind a needle?, any specific way?
fab
Member #: 100
Paris\' suburb
take time ,a fine emery paper, and a micro meter,
but you need a very good lambda meter
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Spin the needle up in a drll...
apply sand paper....
test the result!
alex
AlexF
