| Home > Help Needed / General Tech Chat > coolant plumbing | |||||||
![]() 370 Posts Member #: 181 Senior Member Chard, Somerset |
18th Aug, 2004 at 03:23:18pm
At the moment i'm not running a heater so i have got the cylinder head outlet going into the inlet manifold then into the bottom hose. l've just read on the minispares website however that this is wrong and that it should be plumbed into the top hose. lt says this should be done because the hot outlet from the cylinder head is pumped straight back into the engine without going through the radiator which is bad obviously, so my question is how can i connect the hose from the cylinder head outlet to the top hose? |
18th Aug, 2004 at 04:23:47pm
I run mine into the bottom hose :S
AlexF |
18th Aug, 2004 at 05:07:00pm
I used to do this, but this years engine ran hot, so changed it...
18th Aug, 2004 at 05:10:36pm
maybe l'm being a bit thick but how do you connect the heater tap take off to the top hose? |
18th Aug, 2004 at 05:17:22pm
metro thermostat housing...
AlexF |
18th Aug, 2004 at 05:22:11pm
cheers, off to the breakers again then!! |
18th Aug, 2004 at 05:40:58pm
Not the way i did it...
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
18th Aug, 2004 at 06:16:12pm
Not sure if everyone would go for this, but i drilled a hole straight into the rad and used some JB Autoweld to fix a 1/2" pipe fitting. I then plumbed straight into rad.
195 Posts Member #: 26 Advanced Member Cannock |
19th Aug, 2004 at 01:38:34pm
To be honest i just use a heater matrix then stick that into the bottom hose. However there is quite a bit of extra pipeing involved which of course leave less room for other things |
63 Posts Member #: 325 Advanced Member |
21st Aug, 2004 at 11:30:23am
If you are running a metro rad or using a rad with the same diameter pipes as the metro, use the old water oil cooler rad pipe, this is a rubber t-piece with two rad size connections and one heater size hose! |
