| Home > Help Needed / General Tech Chat > what turbo | |||||||
![]() 368 Posts Member #: 362 Senior Member durham area |
2nd Sep, 2008 at 10:29:04pm
could someone point me in the right direction, looking for a turbo to supply me with 14-16 psi boost on my 1380 16v bmw twink engine will be 8.6:1 cr with max rpm around 7500 utilizing the 254 cams, any help would be excellent. love that straight cut scream!!!
2nd Sep, 2008 at 10:37:36pm
let me go digging. there was a thread on here not to long ago in which Turbo's for the Twinks were talked about.
Edited by James_H on 2nd Sep, 2008. |
2nd Sep, 2008 at 10:53:24pm
Im running the GT17, and it goes well (Now it does anyway, lol)!!
![]() 380 Posts Member #: 1835 Senior Member Thame, oxfordshire |
2nd Sep, 2008 at 11:53:29pm
On 2nd Sep, 2008 matty said: yeah i'll second that!!! i shat myself earlier on...........and im not joking Im running the GT17, and it goes well (Now it does anyway, lol)!!
On 23rd Aug, 2010 Nic said:
Turbophil had a butt plug made that seemed to be suitable. He may have finished with it now and have it kicking around spare |
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
3rd Sep, 2008 at 07:16:32am
I got the feeling from you guys that the GT17 was a little fragile if not bought new ? Or maybe it was just the rebuild kits that where shit.....? I had a look around on the saab forums and they change from the GT17 to a TD04 variant but do say it is a little larger than the GT17 and spool up is alittle slower...What do you guys reckon ? "So wat we gonna do tonight Brain?"
3rd Sep, 2008 at 08:32:37am
Because the GT17's rotating assembly is so much lighter and smaller in diameter I think its alot more vulenrable to being damaged from drawing something in or being out of balance, where as an old T series turbo may be a little more tolerant to being out of balance.
3rd Sep, 2008 at 10:07:49am
On 2nd Sep, 2008 turboestate said:
could someone point me in the right direction, looking for a turbo to supply me with 14-16 psi boost on my 1380 16v bmw twink engine will be 8.6:1 cr with max rpm around 7500 utilizing the 254 cams, any help would be excellent. You need approx 23 lbs/min at a 2.1 pressure ratio. that should provide around 220hp at the flywheel. That a bit much for a GT17 or a GT20. As suggested above a GT25 would be better suited. The method of doing the calcs is in this thread: Edited by Paul S on 3rd Sep, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
3rd Sep, 2008 at 10:58:13am
i reckon .... :)
Edited by robert on 3rd Sep, 2008. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
3rd Sep, 2008 at 11:37:34am
Don't forget running a higher CR (which is quite acheivable with EFI) you can run lower boost and get the same sort of power as a low CR engine on high boost. I got better times on the 1/4 mile with mine on 6psi than my old 5 port did at 17psi.
3rd Sep, 2008 at 05:56:59pm
good insight there must think about this some more looking at the physicl dimentions there doesnt seem to be much change between the three (17/25/28) suppose it depends what sort af a/r you can get seen a gt2860rs but it seems to have a turbine a/r of 0.86 and a compressor a/r of 0.60 which seem a bit large will have to dig deeper, love that straight cut scream!!!
4th Sep, 2008 at 07:30:35pm
Cheers guys. Ill carry on researching and see what i can find. A/R ratios for the GT17 ? Got inlet 0.53 and 0.43 exhaust on a piece of paper here.... sound about right ?
would be a good turbo for the Twinks.
