Home > General Chat > 'minifins'
I'm just about to order some rear drums for the car and after a bit of searching, its apparent there are some imitations of the original super minifins available on e-bay for a siginficant saving over the originals. Anyone got anything to say about them?
I'm not one to cut corners with safety but i'm not one to spend money if I don't need to either
cheers
rob
The one's I got from ebay are really good quality.
Just make sure that they have the steel inserts.
I'd give you the link, but I got mine ages ago.
i have heard they are pap, no good what so ever, tbh do you really need super fins? may as well get spacerd drums, the rear breaks dont do as much work as the fronts *tongue*
The weight saving.
that is true *tongue* i have some original superfins on my mini, dont know weather to keep them of sell them
chinlesswonder
Member #: 1192
In the garage......again!!
good for the unsprung weight, i have a set of Minisport ones and those chinese copies, compared side to side, i can't see a difference, i say get em if you can afford em, they are usually 45-50 quid which is half price roughly.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
On 3rd Sep, 2008 theoneeyedlizard said:
The weight saving.
i have some off at the mo and they weigh 3.1 lbs...*happy*
mini93
Member #: 2017
Warwick.
iv heared storys before of the steel inserts slipping? not sure how true that is though, certainly not something id want to risk
David.
sounds like a story,
mini93
Member #: 2017
Warwick.
just like i said then :p i bet the person i heared it from (cant even remember now) sells them, trying a scare factor pitch.
does anyone know how the steel inners are fixed? interface or built into it's structure?
David.
alandavies215
Member #: 1844
BURNTWOOD, staffordshire
hello
I know hudsrsfield spares sell then cheep
I've got a set of Minifins. They are non spacered.
Ben H
Member #: 184
Melton Mowbray, Pie Country
How insightful. I have some spacers, does that add to the debate.
http://www.twin-turbo.co.uk
The thing is, you cannot buy Minifins anymore. Not for twenty years!
O No not light weight don't they do a heavy alooy one i could buy!
i've got a set of the original minifins already but as Vegard points out - they are non spacered. I could just add separate spacers but the spacered drum would be better.
Hedgemonkey
Member #: 360
I made the mistake of buying HS ones ages ago. I think they are actually cast iron spacered drums with some alloy fins cast on. They are perhaps more heavy than iron drums!!!! The casting also looks second rate.
Sadly, you get what you pay for. The superfins are beautiful things in comparison.
