| Home > Help Needed / General Tech Chat > very embaracing.. please help :) | |||||||
3rd Sep, 2008 at 10:04:58pm
today when i finished work after stripping an engine down, i got home to start stripping apart my turbo lump as i finnally got arround to getting it from my friends house.
3rd Sep, 2008 at 10:09:48pm
Can you get a piston ring compressor in there? although you'd probably need 2 to do them simultaneously! Lol
Edited by matty on 3rd Sep, 2008. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
3rd Sep, 2008 at 10:13:29pm
yeah i was going to go for the remove the crank to get at them that way, as i can remove cyl 2 and 3 to give my self abit more room, i was just seeing if anyone knew if it could be done lol :) Drives
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
3rd Sep, 2008 at 10:27:11pm
one of my mates did the same thing to my block. took the crank out and other pistons and i ended up using a flat blade screwdriver and VERY CAREFULLY poping the ring back in took me a few hours to get it done but got there in the end with no damage to the ring piston or bore. (the screwdriver i sues was v blunt and not sharp on the corners) i dont know of a better way im aftraid but sure someone else must have done it to (i dont even sujest this is a good idea but it worked for me)
"Tuning should be a compromise between what is possible and what is necessary"
3rd Sep, 2008 at 10:29:57pm
Break the rings off and buy new ones On 26th Oct, 2004 TurboDave16v said:
3rd Sep, 2008 at 10:55:23pm
im not worried about the rings or the pistons :) im boring the block +20 and fitting omegas :) but i want to try and keep the pistons to sell on as they are in good nick (std turbo ones)
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
3rd Sep, 2008 at 11:01:41pm
On 3rd Sep, 2008 Sprocket said:
Break the rings off and buy new ones ![]() colin's right, because you may damage these without knowing,its just not worth it... what size? some one may have a spare set.. On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
3rd Sep, 2008 at 11:18:54pm
you twat
3rd Sep, 2008 at 11:21:01pm
On 3rd Sep, 2008 wolfie said:
you twat you want a hand? neil, always so smooth....lol paul i think i have a spare set of rings if you end up needing them, il look friday On 2nd Oct, 2009 Vegard said:
1391 Posts Member #: 1686 Post Whore Oxford |
4th Sep, 2008 at 07:52:20am
thats not so bad, its when your doing your first ever engine rebuild and put things such as thrust washers in the wrong way round. and dont prime the oil pump ect ect. On 19th Feb, 2011 Miniwilliams said:
OMG Robert that's a big one |
4th Sep, 2008 at 07:52:32am
Break the rings off and buy new ones ![]() I was going to say this! Kill 'em all! On 13th Jul, 2012 Ben H said:
4th Sep, 2008 at 07:56:29am
i always brake them off.
4th Sep, 2008 at 02:30:12pm
i may do neil :$, do you still want one my my spair blocks?
you twat you want a hand? Drives
