| Home > General Chat > SC Box Question | |||||||
4th Sep, 2008 at 04:46:00pm
Call me a twonk if its on here somewhere but I've had a little go with the search button but I can't seem to find exactly what I'm looking for.
136 Posts Member #: 1751 Advanced Member chichester/bognor |
4th Sep, 2008 at 04:48:01pm
also slightly off topic,it is about straight cuts though,i heard straight cut gears dont last awefully long is this the case.
On 30th Aug, 2008 Richie said:
too much my wife says "not that friggin site again" so i pull my pants back up and turn it over to TM. iam on pretty much every day as i lead a sad existance |
4th Sep, 2008 at 04:49:46pm
from what I gather it is true about the increased wear rate but not too sure how much it is increased by. If something is worth doing, it's worth doing half of. |
4th Sep, 2008 at 04:57:32pm
I've yet to hear of a cross pin being broken so wouldnt worry too much. |
4th Sep, 2008 at 04:59:04pm
what about the gearset? layshaft etc? If something is worth doing, it's worth doing half of. |
4th Sep, 2008 at 05:33:02pm
That’s basically the set up i have but a different ratio in the drops. You should be able to run big power.
4th Sep, 2008 at 06:25:27pm
120-140bananas similar sort of curlies If something is worth doing, it's worth doing half of. |
4th Sep, 2008 at 06:37:18pm
On 4th Sep, 2008 minimadmotorman said:
120-140bananas similar sort of curlies I'll be running helical gears with about 120HP so I hope your gearbox will hold up
Gary's description is best |
1391 Posts Member #: 1686 Post Whore Oxford |
4th Sep, 2008 at 06:55:52pm
i am, no signs of damage yet from inspection.
Edited by Sam on 4th Sep, 2008. On 19th Feb, 2011 Miniwilliams said:
OMG Robert that's a big one |
4th Sep, 2008 at 06:58:29pm
i got about 30,000 miles out of mine before a tooth snapped off first gear (which was a std 1st with a clubman set) the rest of the gearset was pretty worn though, the laygear was pitted a fair bit too. would have been fine for a few thousand more miles running at 170lb/ft but i got rid to be safe while it was still sellable. On 20th Oct, 2015 Tom Fenton said:
4th Sep, 2008 at 10:10:11pm
sc gear will always pit due to there desgn, however with decent oil used like millers ctv will help.
4th Sep, 2008 at 10:38:38pm
the drops and diff are find for say 300 + it the rest is the problem for say over 240 -250 ish. I've found. Edited by Miniwilliams on 4th Sep, 2008. Best 1/4 mile 13.2 seconds @116 mph
5th Sep, 2008 at 07:43:18am
matt its when you can say that you know your a true nutter. On 19th Feb, 2011 Miniwilliams said:
5th Sep, 2008 at 08:59:41am
Excellent. That means this box should hold up to anything I am going to throw at it.
5th Sep, 2008 at 09:08:33am
well, NO
5th Sep, 2008 at 09:31:40am
I know that if you treat your toys with the respect they deserve that they will last much longer.
5th Sep, 2008 at 10:39:53am
Yes Shed is right, you can smash a box up with just 120 bhp if your an arse. Best 1/4 mile 13.2 seconds @116 mph
