| Home > Help Needed / General Tech Chat > lacking fuel | |||||||
14 Posts Member #: 212 Member |
18th Aug, 2004 at 11:42:34pm
i have a 1275 mg turbo engine in my mini it runs perfect till the turbo cuts in then its lacking fuel has anyone got any ideas why this is and what the fuel pressure should be (ive got 2 1/2 from pump) also does anyone know if there is a uprated inlet manifold gasket available as ive got through 3 in a month |
18th Aug, 2004 at 11:50:01pm
do a search mate as all your questions come up with alarming regularity (except the gasket one.. jsut use good gaskets and torque it up roperly!) turbo 16v k-series 11.9@118.9 :)
19th Aug, 2004 at 12:00:04am
ive checked every thing and they are all fine (fuel pump fuel lines fuel regulator ) all was fitted new about a month ago ive got a standard mg turbo pump would i need a more powerfull pump |
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
19th Aug, 2004 at 12:06:27am
Your pump should push out at least 30lbs |
19th Aug, 2004 at 12:49:46am
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2026
-MINI CLUBMAN 1380 TURBO- |
19th Aug, 2004 at 12:52:27am
you done a search yet turbo 16v k-series 11.9@118.9 :)
![]() 370 Posts Member #: 181 Senior Member Chard, Somerset |
19th Aug, 2004 at 10:47:16am
outlet pressure from the reg. to the carb. should be 3.5psi at idle and should stay at 3.5psi until boost transision then rise in proporsion with the boost i.e. if you've got 5psi boost then you should see 8.5 psi fuel pressure. |
![]() 198 Posts Member #: 345 Advanced Member Guildford Surrey |
19th Aug, 2004 at 12:48:46pm
You need to set your fuel pressure between 3.5 and 4 PSI on the carb side of the pressure regulator. Your exhaust manifold may not be flat so we suggest you get the faces machined and use a genuine turbo gasket. |
19th Aug, 2004 at 01:08:27pm
Has anyone got hold of any genuine turbo gaskets recently ? |
19th Aug, 2004 at 02:26:37pm
They are exactly the same as twin point gaskets I was told...
AlexF |
19th Aug, 2004 at 05:03:49pm
I got 8 exhaust gaskets from minispares around 2 months ago...
23rd Aug, 2004 at 09:33:52am
i use a gasket from avonbar, you pay more but it has the metal rings arround the cut-outs. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
23rd Aug, 2004 at 08:00:07pm
if youve checked everything and its all ok then youve missed something or not checked it right. (didnt mean to sound blunt)
24th Aug, 2004 at 06:45:57pm
Just a quick note to you guys on the subject of exhaust gaskets, the o/e turbo ones are NOT the same as the injection Minis, also the MPi has an all steel face withvery thin metal support rings which is a very good gasket but not for turbo use. |
check the gasket between the carb and plenum you may be useing a NA gasket,check the balance pipe? tried the t-piece trick?, and tehres a few threads on setting the fuel pressure correctly :)
