| Home > Help Needed / General Tech Chat > MOCK UP ENGINE | |||||||
141 Posts Member #: 2408 Advanced Member surrey / ewell area. |
5th Sep, 2008 at 03:57:10pm
Hi everyone im gonna bite the bullet and go turbo. gonna try and construct a side mounted turbo like the janspeed jobby. Im just wondering if i can use my spare 998cc a plus as a mock up engine to save taking my 1293 a plus out, is there a difference with manifolds or anything ? just a thought, it would save alot of hassle only have a small garage !!Once built built im gonna port it over to my engine in the car.:) |
5th Sep, 2008 at 04:10:13pm
I think I'm right in saying the 998 block is shorter (in height) than the 1275 block.
5th Sep, 2008 at 04:10:25pm
from what i remember the only problem i can think of, with the 1275 the whole engine is around an inch taller therefore the cylinder head sits higher in relation to the gearbox you can use the 998 head to mock up the manifolds however if its going to be a side mount turbo the hight problem might come into play
Edited by Brett on 5th Sep, 2008. Yes i moved to the darkside |
5th Sep, 2008 at 04:30:03pm
it is 3/8" shorter than the 1275 - so bear this in mind when doind it.
5th Sep, 2008 at 05:29:11pm
you could put some washers on the head studs to space the head up a bit for manifold mock up? "Turbo's make torque, and torque makes fun"
