Home > Help Needed / General Tech Chat > carb question and butterfly question, help needed, sorry
chinlesswonder
Member #: 1192
In the garage......again!!
done the search, but still can't find an answer, there seems to be a small hole on the carb near where one of the plenumn bolts go through, whats it for and should it be blanked off, when i put the plenumn on, the gasket did not have the gole in it for this so i punched a hole through, just wondering if itis contributing to the excessive air intake.
And also, is this butterfly correct, it see to have a screw with a spring on, is it the poppet valve? will it be ok to leave on.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
This hole is vital do not blank it off! If there is not a hole in the gasket already made one.
Read this cracking post by TD for more info:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2103
Edited by Rob H on 7th Sep, 2008.
Butterfly is correct, but you can usefully replace it with a solid type to get rid of the obstruction caused at full throttle.
chinlesswonder
Member #: 1192
Rob, that thread you posted was great, easily explained the balancing of the carb. I'm a lot wiser for that, cheers.
Don't thank me, thank TD for explaining the workings of a boosted SU in plain English.
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Just rebuilding my turbo '44 at then moment and have had a read through this thread:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=1675
I bought the carb service kit from Avonbar which didnt come with a solid butterfly.
So, can I use this butterfly with the poppet valve then? Will it obstruct the flow that much?
I cant see where else you can buy the solid butterfly's from apart from that rebuild kit!!
You can use the butterfly with the poppet valve, yes. Obviously removing it will help flow a little, every little helps.
The full rebuild kits i sell always have the solid butterfly in them, so your kit should have had one in.
richminiturbo.
Member #: 719
Nah it doesnt which is a pain, i only bought the service kit and it seems to be the only thing that isnt in it!!
Dont suppose you could supply me a butterfly without the poppet valve phil?
Jay#2
Member #: 648
Northern Ireland (ex AUS)
You can cut out the valve and braze the hole over. I don't really get why there is a poppet valve in turbo SUs, it must allow a lot of air through when your on boost and you snap the throttle shut!
On 7th Nov, 2008 Nic said:
naeJ
m
richminiturbo.
Member #: 719
Hmm got now access to braising!!
Will a nut an bolt do? *tongue*
Pain in the arse! Should have just got the full rebuild kit instead of the service one, typical tight bastard.
Turbo Tel
Member #: 588
Delaware, USA
You can buy just the butterfly disc at minispares, comes with a couple of extra gaskets.. 6 quid or so??....
Terry
richminiturbo.
Member #: 719
Thanks terry!
Looked on minispares, found this kit:
http://www.minispares.com/Product.aspx?pid=38159
Says for HIF38 but couldnt find one for the HIF44. Description says "same butterfly as on all 1.5" carbs." Will this be what im after?
Jay#2
Member #: 648
The HIF44 is a 1.75" carb though.
Found this:
http://www.minispares.com/Product.aspx?pid=42387
http://www.minispares.com/Product.aspx?pid=38162
I think the difference in the turbo and non-turbo kits is the gaskets not the disk.
Edited by Jay#2 on 22nd Sep, 2008.
naeJ
m
richminiturbo.
Member #: 719
Found this:
brilliant thanks buddy!
"Throttle Disc" for fuck sake! I was looking for the obvious "butterfly", of course it wouldn't be that simple
Yeah Phil, the kits i order i spec with a plain disc so they will have carried that on.
*smiley*
Might restrict the airflow a bit, lol.
best thing to do is solder it up to make the neatest job without buying a new plate.
