Home > Technical Chat > unlocked mini ecu.
ashley_dude00
Member #: 1751
chichester/bognor
just been offered a rover mini ecu fully unlocked.and mappable.would i be able to turbo it injection from mpi to mpi turbo just by lowering compression.if not im going the carb route,but this is quite a special item so would like to do somethin a little different
the ecu is a test ecu.so all normal ecu functions just mappable.was mr.john coopers old ecu from his mpi.
Edited by ashley_dude00 on 9th Sep, 2008.
On 30th Aug, 2008 Richie said:
too much my wife says "not that friggin site again" so i pull my pants back up and turn it over to TM. *wink* iam on pretty much every day as i lead a sad existance
if the ecu is fully mappable then in theory you could to all sorts including turbo's, lowering the compression would enable you to run more boost yes
however, i did not think the mini (mpi or spi) ecu was rewritable? or even if it could be modified to be re mappable i thought it could only be mapped once at the factory and thats that, the ecu on my supra is the same
EDIT: what cc rating is the fuel injector(s)? if all goes ahead then that could be a problem
fuel injecting a turbo 5port A series is abit hit and miss, getting the afr correct in all the cylinders is a bit suck and see i think thats why i have never seen any*wink* well not 5 porters, i have looked into this for my own build, there is so little information about i went carb*wink*
its the whole 5 port thing*wink* just go 8 port, 16v, then efi, then turbo and you have cracked it*happy*
Edited by Brett on 9th Sep, 2008.
ashley_dude00
Member #: 1751
chichester/bognor
yeah its mappable because it was john coopers personal one so its a bit of a one off,yeah i think the injectors would need to be upped,but would also like to know that would it be possible to change timing and that,buti guess its a bit try it.its remappable.have you seen the injection system on john coopers car a one off special 1430 engine with a cooper grages bespoek injection system il get some pictures for people to see and thats fully mappable.
pictures would be great, the only fuel injection engine i have worked on have been non mini, so i can only advise in general terms im afraid :) but its basically measure the air and correct amount of fuel, get it to ignite at the right time and bobs your uncle the rest is up to the mapper,
Which is it SPi or MPi?
If its SPi then I recon its an MBE, and was fairly common in the lat 90's *wink*
ashley_dude00
Member #: 1751
chichester/bognor
its an mpi one.a test one from the john cooper garages,would like to see if it works.is there a way i could maybe give it test if put turbo etc on,what boost on a standard mpi engine.if it works i know hes got the person who created the ecu to maybe unlock it for people.do people think the mpi setup would work well??ie inlet etc.
alpa
Member #: 2093
Grenoble, France
Yes it will work well :) .
