Home > General Chat > the hogs rolling road result
turbo hogster
Member #: 178
stowmaket suffolk
well finaly got onto the rollers after some 500 miles and some ctv fitted.
the old engine on a 8.4 cr made 130 on 9psi and 170 on 16psi.
so with a drop to 7.8 was expecting some 10 bannanas less all over.
well quiet pleased realy got 124 on 9 and 164 on 16psi so pretty pleased. needed no other adjustments but ray said fit and extra standeard spring in the damper as it was ramping a bit when coming on boost causing a slight lean until it catches itself up. so done that and the avr reading is better but just need some stp to stiffen the gearoil up in the dash pot.
so over all a good result the car goes bloody well, when i get to next spring then i will boost her up to 18 and may be 20.
then i get to the point i then need a 360 deg bearing in the blower.
Good stuff. Is yours a 1380 ?
They are some good numbers.
Well done Mr Hog!
top stuff mr hogg
Very goood matey!
Goodwork!!
Hopefully you wont have too many troubles now
you got there in the end!
well done
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Top result. :)
On 19th Jan, 2010 wil_h said:
T3Tone
Member #: 252
Sunny suffolk
Well done matey, looks like rays rollers giving consistant reading yet again.
Hope this is the start of even more cake for the hog
-MINI CLUBMAN 1380 TURBO-
Well done buddy, good figs there sounding spot on. pleased for you, i hope you have many miles of happy motoring from now.
for a 0.6 drop in CR your are playing safe! with upping the boost in the future! ...... but at the expence of fuel economy and a tad more spool up time.
i run a cr of 7.37:1 *wink*
Edited by BENROSS on 12th Sep, 2008.
turbo hogster
Member #: 178
stowmaket suffolk
cheers guys for your kind replies, been a shit year for the hog so touch wood every thing now hunkie dorry and the new garage is taken shape, hopefully soo she will be back in the dry.
yes with that low cr i have plenty under my belt for more boost and saftey to boot so watch this space.
Pistons still intact???
An update on some previous posts could be useful.
