Home > Help Needed / General Tech Chat > Tyre pressures 32R's
Hi Guys, what tyre pressures do you use on your 32R's?
Also if you had a 32R on a 5" wide rim, and a 7" wide rim, would the ideal pressure be the same??
28 psi front and back in mine.
Unsure about rim width making a difference though
Paul
I'd beleive that narrower rim will need higher pressure.
Two weekends ago in a yellow marcos, we started with 28psi on a 6" rim. The pressure was well over 40 after some rounds on track. I'd guess that 25ish would be a godd starter for track use. However, I've got little to no experiance on this. Have a go!
Paul, what width are your wheels?
so what characteristics would an under and over invlated tyre give?
mine are 6" Jim, I would guess that a lower tyre pressure would be of advantage on a 7" rim with a lot of negative camber as it would give the best tyre to road contact when going straight or round a corner - like I say its a guess.
paul
28 for me as well 6 3/4 rims
28 for me when not on the strip, 10x7's but no real miles to say good or bad!
Carl S
Member #: 1761
Stalker
Uneven tyre wear!
id better get the pump out then.....lol
28psi cold is WAY to much on track, that's for sure.
Edited by Vegard on 12th Sep, 2008.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
I have used 26 psi on track with my setup. I have 4.5" rims though...
2 Bar for me.
My eyes can't read the smaller graduations on the gauge.
miniminor63
Member #: 672
Oslo, Norway
thats a lot though, is that on 032rs?
2 bar is 29.4 psi
Scruffy
Member #: 328
Seaford Rise, South Australia
About 30psi on track with 6.5J x 10s and 24psi rear
On 5th Sep, 2011 Vegard said:
Turbo Tel
Member #: 588
Delaware, USA
On 12th Sep, 2008 Paul S said:
2 Bar for me.
LOL...how many pairs of reading glasses do you have placed around the house..
I have 4 pair plus a small pair in my toolbag!!
2 Bar for me.
I have a pair permanently hung around my neck.
Old age creeping up I think.
Edited by Paul S on 13th Sep, 2008.
Hot or cold?
Richminiturbo found this and posted it on TMF not long ago. If you know the ideal tyre pressure for the tyre, then you can tune the pressure to that. I thought it was very interesting, but at the same time it became obvious *Idea*
Im sure there is an ideal operating range for the A032s, that is all you need *wink*
The ADVAN A048 needs to operate in the 33 to 36 psi window for maximum performance. So you have to figure out how to make your tyres reach this window when you need maximum performance. A hillclimb car may start with tyre pressures in the window because the tyre pressures are unlikely to climb very high in a short 40 second run with no warm-up lap. A big heavy car like one of the Yokohama V8 racing utes competing in a 10 lap race may start with a pressure of 28psi. The big heavy high horsepower car is going to work the tyres hard so the tyres will build a lot of heat. As the air in the tyres expands the pressure goes up. So the ute may reach the pressure window by lap 3! The first step to figuring out the best tyre pressures in your ADVAN A048s is to start with a tyre pressure you think will rise beyond the operating window then go out on the track and do your normal race distance. Come straight in and bleed pressure out of the tyres so they come back to say 35psi which is in the middle of the pressure window. Then let the tyres cool completely and measure their cold pressure. This is a good indication of what your starting pressure should be. Further refinements can be made by measuring the tread surface temperature variation with a pyrometer and adjusting starting pressures depending on track and ambient temperatures.
Edited by Sprocket on 14th Sep, 2008.
Interesting, and makes sense in a way, but what happens for instance when you have the DON weighing 440kg on these tyres? I know that if we had 33-36psi in when HOT then it would be awful, as the car isn't heavy enough.
What you have to remeber tom is that the paragraph above is aimed at normal road use or track use where corners are concerned *wink*
On a straight 1/4 mile, lower pressures that promote better grip, rather that cornering stability is of higher importance *wink*
Im sure you know that :)
Oh on weight wont matter, as if the tyre works best at 'X' psi warm, then weight wont matter, as the tyre wont be worked as hard, so you will start with a higher cold pressure.
Scruffy
Member #: 328
Cold Vegard.
You are looking for a hot rise of no more than 3-4 psi. Any more an the tyres are under inflated and less and they are over!
