Home > Help Needed / General Tech Chat > clutch judder
I have now put 200 trouble free miles on the new engine however am slightly annoyed by clutch judder that seems to occur when letting the clutch up slowly.
There is no judder when it is released fairly normally such as pulling out a junction on an uphill slope.
The set up is a minispares ultralight flywheel, lighened backplate and orange diaphram.
Does the whole set up simply need a littly more time to bed in as its all new?
Your thoughts please.
yes get a few more miles on it first
Mr Joshua
Member #: 1954
Luton Bedfordshire
Had this before cant rememer what part was at fault, pressure plate or flywheel but which ever one it was it was warped. Sent the assembly back twice, third time was the charm.
If the problem does not self cure read the above.
Own the day
