| Home > Help Needed / General Tech Chat > best way to do a manifold gasket | |||||||
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
22nd Aug, 2004 at 09:12:58pm
Oi !! TurboLessTosser |
![]() 2641 Posts Member #: 19 Post Whore newcastle |
22nd Aug, 2004 at 09:20:03pm
can`t see how exhaust would move enough for you to remove the turbo off the manifold studs .just undo exhaust clamp and let exhaust drop , then push turbo back, return pipe should stay on , not easy job and no real short cuts. Everyone knows that instructions only have to be read if the thing doesn't work....
22nd Aug, 2004 at 11:27:04pm
Pain in the arse job!!! On 21st Jan, 2011 fastcarl said:
23rd Aug, 2004 at 08:15:23pm
remove the plenum (allows you to move carb plus inlet manifold towards the bulkhead.
63 Posts Member #: 325 Advanced Member |
23rd Aug, 2004 at 08:31:59pm
Remove the manifold studs, takes about 30 mins and gives you a bad back! |
23rd Aug, 2004 at 08:42:09pm
how do you remove the 2 studs under the inlet without removing the carb/inlet first.
23rd Aug, 2004 at 10:23:59pm
poo poo
TurboLessTosser |
24th Aug, 2004 at 07:36:11pm
There is another thread talking about the manifold gasket. Avonbar posted a comment saying that the mpi steel gasket is thinner than the turbo one. I have just put a mpi gasket on, it seems to have sealed ok - I will let you all know how long it lasts, oh and the standard exhaust manifold gasket lasts about 30 miles! |
