| Home > General Chat > ot electric power steering | |||||||
17th Sep, 2008 at 10:20:54pm
a power steering rack for the camper new is £800 and around £400 for a s/h one thats unknown
17th Sep, 2008 at 10:22:44pm
The current generation of Toyotas use electric racks too On 12th Nov, 2009 Paul S said:
Gary's description is best |
17th Sep, 2008 at 10:30:43pm
corsa's and punto's use electric columns.
17th Sep, 2008 at 10:36:12pm
Most electric power steering I've come across is an electrically driven hydraulic pump. BINIS, Saxos/106s etc have this setup.
17th Sep, 2008 at 10:39:31pm
On 17th Sep, 2008 James_H said:
corsa's and punto's use electric columns. corsa's are speed sensitive but can be overridden (not cheap) puntos couldnt be assed to develop the speed sensitivity so they shuved on a "city button" to make it lighter when you want to park. its the second gen putno's that come with that column. electric racks though i have not a clue. what ever they sound rather new and expensive and in either case you will be pretty hard pressed to find one in a scrappy. sorry its column i ment, sounds like the punto is the one i need Crystal Sound Audio said:
17th Sep, 2008 at 10:49:16pm
most of the new generation of toyotas use electric coloums the trouble is im pretty sure most cars that have a electric coloum will require a speed signal. as you need less steering assist at speed. toyotas i know that have electric coloums are yaris from about 52 plate maybe abit earlier, last shape corollas, present shape avensis lots more i cant think off. lol they all have seperate ecus. the spead signals normally come from abs sensors via abs ecu. dont know how they would work without the speed signal.
17th Sep, 2008 at 10:51:47pm
there are little boxes that you can buy on ebay that are basically a signal box for the column ecu which then give you the ability to adjust the sensitivity but the last time i checked they were around £100+
17th Sep, 2008 at 10:54:56pm
hmmm good old ebay lol . punto coloum could be the answer.......but fiat i couldnt do it lol no longer a series, but still 1.3 turbo.
18th Sep, 2008 at 11:36:53am
I know a lot of the rally boys use corsa ones, On 15th May, 2009 TurboDave said:
2 Posts Member #: 617 Junior Member |
18th Sep, 2008 at 03:08:53pm
http://www.16vminiclub.com/forums/viewtopic.php?t=8409
Edited by DarrenW on 18th Sep, 2008. |
19th Sep, 2008 at 05:26:21pm
107 has one on the rack. quite a few have been writen off so there will be some floating arround Drives
