| Home > Help Needed / General Tech Chat > my car keeps cutting out | |||||||
100 Posts Member #: 344 The Royal Mail lose every parcel I ever send.....and I am a TWAT |
23rd Aug, 2004 at 08:19:01am
hi guys hope you can help my car starts up fine runs for say 1 min then just cuts out but then you can start it straight back up againwhen its cutting out you can give it some throttle but it doesnt do asnything. i have taken the engine from my mk1 metro and put it into my g reg 1 is there anything diffrent it can iether be fuel or its loosing spark i guess please help thanxs lads |
126 Posts Member #: 244 Advanced Member |
23rd Aug, 2004 at 04:45:21pm
check that you have oil in the carb dashpot. Speedster turbo under construction |
23rd Aug, 2004 at 07:07:31pm
yes got that
23rd Aug, 2004 at 07:27:03pm
is your fuel pump wired up properly? not sure what system they use on them if its like the era circuit perhaps your fuel pump isnt running with the ignition on (pos 2)just running when the ignition is turned to crank (pos3) this fills the carb and will run for a while to check your circuit just give the pump a live and earth from the battery and see if it runs for longer butDO NOT drive the car with the pump wired up like this.
24th Aug, 2004 at 08:15:33pm
what minime said. Speedster turbo under construction |
11 Posts Member #: 67 Member Hitchin Herts. |
29th Aug, 2004 at 03:47:18pm
See the description of fuel pump circuit on our website under 'Technical' on LH side.
