Home > Help Needed / General Tech Chat > piston / deck height
littlejem59
Member #: 2544
Biddulph, Stoke on Trent
Omegas are based on the old hepolite performance piston designed i think in the 70's (can provide the number if it's important) but beefed up around the crown and lands. now the omega is the same basic design with the same piston to deck height of 40 thou on a standard block. it would be advisable to measure your base to deck height to make sure you have the correct clearance or better still install the pistons and vernier the clearance. My block had been refaced to true it up so mine were around 5 thou less at 35 but there was a plus or minus 10 percent variance between the cylinders meaning a well dynamically balanced engine would require some 'blueprinting' to equalise CR's between cylinders.
Rob
Edited by littlejem59 on 19th Sep, 2008.
It's not the age that makes me creak it's the mileage
littlejem59
Member #: 2544
OH S***! what a muppet, sorry guys this should have been part of Turbo Tels thread. Dohhh:$
