| Home > General Chat > carbon fibre | |||||||
271 Posts Member #: 1844 Senior Member BURNTWOOD, staffordshire |
20th Sep, 2008 at 07:42:34am
hello
![]() 2102 Posts Member #: 432 Post Whore Swindon |
20th Sep, 2008 at 08:00:24am
do you use the car on the road? if so avoid the doors, get ali skimmed ones intead. |
20th Sep, 2008 at 08:05:53am
yes I do
20th Sep, 2008 at 09:19:50am
Usual suspects: TDK & Curley Isambard Kingdom Brunel said:
20th Sep, 2008 at 11:57:27am
tdk & abs get my vote "Turbo's make torque, and torque makes fun"
20th Sep, 2008 at 12:26:03pm
what are the problems with the fiberglass/carbon doors on the road then? do they crack alot? |
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
20th Sep, 2008 at 05:07:43pm
they leak lol On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
![]() 9326 Posts Member #: 59 First mini turbo to get in the 12's & site perv Herefordshire |
20th Sep, 2008 at 07:42:58pm
and get a double skinned boot lid |
1391 Posts Member #: 1686 Post Whore Oxford |
20th Sep, 2008 at 10:02:54pm
James_h at anything above 80 they flap like a penguin trying to take off.
OMG Robert that's a big one |
21st Sep, 2008 at 07:36:33am
sounds like carbon is not all it's cracked up to be then |
21st Sep, 2008 at 08:50:26am
I don't think that it is a failing of the material. The doors are designed for light weight. If you designed some for road use they would be fine, but nobody does because they would not be much lighter. http://www.twin-turbo.co.uk
656 Posts Member #: 1917 AKA chargedzetec Milton Keynes |
21st Sep, 2008 at 09:26:27am
On 21st Sep, 2008 Ben H said:
I don't think that it is a failing of the material. The doors are designed for light weight. If you designed some for road use they would be fine, but nobody does because they would not be much lighter. in my opinion its down to method of manufacture. its basically because they're done using wet lay, without using a material for the job. carbon isn't just carbon, they're many different types. Unfortunately the ones that are suitable, are too expensive to use, and make a profit from selling the doors. This is FORD country, on a quiet day you can hear Vauxhalls rusting. |
21st Sep, 2008 at 11:20:41am
If you made the doors of the design we are talking I don't car what fancy material you use it will never be stiff enough. Which is no problem as that is not what they are designed for.
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
21st Sep, 2008 at 04:22:31pm
don't use curley, there caron fibre can't take heat at all, leave it in the sun and goes all milky, mines in the paint shop at the moment, being sprayed because of this......
"Cars are a lifetime of pain" |
21st Sep, 2008 at 05:57:33pm
i've got a curley bonnet, the fits not the best but as said above there for race use and fit isnt really an issue, other than that its been fine |
21st Sep, 2008 at 08:59:44pm
Exactally. the way i make mine is called infusion, you tube it. i cant be arsed to explain.
I don't think that it is a failing of the material. The doors are designed for light weight. If you designed some for road use they would be fine, but nobody does because they would not be much lighter. in my opinion its down to method of manufacture. its basically because they're done using wet lay, without using a material for the job. carbon isn't just carbon, they're many different types. Unfortunately the ones that are suitable, are too expensive to use, and make a profit from selling the doors. On 19th Feb, 2011 Miniwilliams said:
22nd Sep, 2008 at 07:53:13am
On 21st Sep, 2008 Sam said:
Exactally. the way i make mine is called infusion, you tube it. i cant be arsed to explain. then poped into a wooden box lined with steel and 5 hair driers at either end. and left to cure under vacume. (works well) So do the doors you make with this method stay in place at speed? Edited by Ben H on 22nd Sep, 2008. http://www.twin-turbo.co.uk
22nd Sep, 2008 at 08:03:54am
i havent made doors, however i wouldent make doors fully out of carbon.
22nd Sep, 2008 at 09:33:17am
On 22nd Sep, 2008 Sam said:
i havent made doors, however i wouldent make doors fully out of carbon. id use a steel door, leave the edges of the skin in place about 4cm all the way around. then bond a carbon skin to the inside of that. wouldnt that look a bit odd with the lip all the way round and the skin on the inside? also would it be any lighter than ally? |
22nd Sep, 2008 at 04:52:55pm
Wouldn't a cross brace made up of a foam core and carbon layer work? It should stiffen things up considerably and not weigh much. Or a honeycomb core could be used if you want the fancy stuff.
22nd Sep, 2008 at 10:51:55pm
its not the lower doors, its the upper frame.
23rd Sep, 2008 at 06:25:14am
what kind of prices do you charge for various pannels mate |
23rd Sep, 2008 at 07:30:13am
Im not for the moment, im not practised enough.
