| Home > Help Needed / General Tech Chat > wont run correctly without choke. | |||||||
![]() 1014 Posts Member #: 238 Post Whore essex |
21st Sep, 2008 at 05:32:22pm
over the past week my car has been running really bad, a lack of power, wouldn't really rev past 2500-3000rpm, and was much worse under load..so i've changed the plugs, leads, dizzy cap rotor arm and coil and it was still doing it, but noticed today that it runs fine with a little bit of choke..would this mean that the carb is in need of adjustment or will it need a rebuild? ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
21st Sep, 2008 at 05:39:58pm
i had this probelm when i didnt have an airfilter on my N.a mini, also found out there was a slight air leak. may need a clean up of the carb and abi of a tune up. have you changed anything with boost or parts? Drives
21st Sep, 2008 at 05:48:55pm
nothing was changed before it started running badly, went to work and it was fine, left work and it was running like this.
21st Sep, 2008 at 05:53:59pm
Check your regulator and fuel pressure. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
22nd Sep, 2008 at 07:21:56am
also in this codl weather she will lean out any way so may just need a richen up a bit try a 1/4 turn at a time. always looking for them bigger bunches of bannanas |
22nd Sep, 2008 at 04:51:37pm
how weird..its running fine today??? ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
22nd Sep, 2008 at 05:23:52pm
i assume its turbo? does it have a piston dump valve? sometimes they stick open |
22nd Sep, 2008 at 05:36:49pm
hi pressure and low barometer readings plays funny things
23rd Sep, 2008 at 06:50:21am
yep i agree with benross, i recon its very near the misture limit opn a warm day so when cold temps are in the sir then tips it over the edge and runs lean, try a 1/4 turn richer should soon be better as its getting colder now.
23rd Sep, 2008 at 09:57:05am
i was thinking that a visit to uncle ray may be on the cards, but i might aswell get the megajolt fitted first then pay him a visit... ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
24th Sep, 2008 at 08:07:33am
yep ok no probs but just give a 1/4 turn richer to be on the safe side. always looking for them bigger bunches of bannanas |
24th Sep, 2008 at 12:42:05pm
Check the balance pipe at the front of the carb a pin prick in that will have you runnung around in circles for ages. I put a new one on mine a few years back and it had the smallest hole in it but it was enough to royaly mess things up. Own the day
