| Home > Help Needed / General Tech Chat > T2 turbo elbow......... | |||||||
23rd Aug, 2004 at 11:42:29pm
Do you need to fit a gasket between the turbo and elbow or is it just a straight mating face??............ |
24th Aug, 2004 at 09:19:02am
I don't use a gasket; just make sure the faces are nice and flat... On 17th Nov, 2014 Tom Fenton said:
25th Aug, 2004 at 05:10:06pm
thats what I thought... great |
27th Aug, 2004 at 12:01:55am
ive used a gasket |
27th Aug, 2004 at 11:03:39pm
what kind of gasket greypride??
27th Aug, 2004 at 11:42:43pm
its a steel one, no the engine is still on standard mounts and stabiliser bar, i might change it to a longer one if it touches but i think i may just get away with it |
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
29th Aug, 2004 at 11:31:24am
The gasket is a steel item. It is made so that it is compressed when the bolted up between the turbine housing and elbow. However i have also used no gasket here as well. The turbine elbows have been surface ground to ensure that they are flat. I would use a gasket if you have them available. All turbo rebuilders will sell you them. I will have a stock of them on the shelf soon. |
29th Aug, 2004 at 04:49:58pm
ok thanks everybody |
