Home > Help Needed / General Tech Chat > fuel ines
PEP
Member #: 1145
North Wales
Awright guy's?? Just had a look at the fuel lines in my boot. One looks like its 6mm and the other is 8mm. need 2 replace the lot.do i have to stick to these sizes??? Is there a 2 different sizes-return etc?? Thanks.
use the search button. there is alot of information about fuel lines and sizes for optimem and what people prefer to use.
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Im using 8mm feed and return
PEP
Member #: 1145
North Wales
Thanks guy's
Mr Joshua
Member #: 1954
Luton Bedfordshire
I use 10mm feed and return. The rule is that your return should be of greater capacity than your feed, If you know what your pump outlet is all you have to do is fill in the blanks.
Edited by Mr Joshua on 26th Sep, 2008.
Own the day
richminiturbo.
Member #: 719
Edited by richminiturbo. on 26th Sep, 2008.
