| Home > Wanted > WANTED MEGAQUIRT.............. | |||||||
![]() 134 Posts Member #: 664 Advanced Member South Wales (chepstow) |
28th Sep, 2008 at 10:57:06am
Ive decided to try the megasquirt set up, im currently running the megajolt set up and it works well.
28th Sep, 2008 at 11:11:40am
What do you intend to use it for, ie, fuel as well as ignition or just the more advanced features for ignition ???
29th Sep, 2008 at 04:46:51pm
yep fuel as well as ignition cheers
29th Sep, 2008 at 05:02:56pm
On 29th Sep, 2008 ROB1N said:
yep fuel as well as ignition cheers OK, don't take this the wrong way, but I suggest you start reading up on the "A Series injection" part of the forum...... Unless you are using a 7 or 8 port head, this is not a simple subject :) Schrödinger's cat - so which one am I ??? |
