Home > Technical Chat > Miglia Subframe mounting
Tareq
Member #: 970
Bahrain
Hi, I was wondering if anybody had some ideas about the way the Miglia's have their subframes mounted.
Looking at some of the pictures on the web I see that the front subframe is raised by removing the lower mounting on the tower bolts. I guess some sort of spacer would be needed to center the tower bolts in the holes? Also I read somewhere that the bolts are bored out so that the hilos can be adjusted through the tower bolt.
If anybody has an clues about this would really appreciate the help. I'm building a track car and trying to run it quite low.
have you got any pictures of the subframes i have never seen one before from a miglia setup.
paul
Tareq
Member #: 970
Bahrain
Not the clearest picture but I think you probably can see what I mean.
Thanks to the photographer.. No idea where I nicked the pic.
Tareq
Member #: 970
Bahrain
Having a brain fart... cant get the picture to show
sorry
Tareq
Member #: 970
Bahrain
Guess I figured how to post a pic.
CHeers
Its a trick way of lowering the car but keeping the steering and suspension geometry right as well as driveshaft angles
Tareq
Member #: 970
Bahrain
Sprocket.. Do you know if a bushing is needed to keep the tower bolts centered in their holes in the body?
no mate i dont, however if i were to do it, i would just sit the body onto the subframe and fit both solid mount bushes on the top back to back
Tareq
Member #: 970
Bahrain
Thanks.. I try it out.
Tareq, thats my friends car in that photo, and I know the car builder very well.
Cut the lip off the top of of the subframe tower (around where the bolt goes in) so it's flush with the top of the subframe.
This is mine,
machine a spacer up the same thicknes of both subframe spacers, (I'll measure mine tommorow) and mount above the cross member, there is nothing between the body and the subframe.
you will also need to fabricate lower subframe mounts,
Why do you need to cut the lip off the subframe Jim?
Tareq
Member #: 970
Bahrain
Got it... Thank Jimster
Would it be a good idea to try and raise the rear subframe aswell?
well you don't really need to, but it's doing nothing now as it's not locating the rubber, there is no thread in it so chop it off to save the evil weight
The rear is also solid mounted,
Tareq
Member #: 970
Bahrain
Perfect.. Thanks for the info and pics.. Guess I got some more fabricating to do.
