| Home > Help Needed / General Tech Chat > Changing The Manifold Gasket | |||||||
![]() 862 Posts Member #: 1660 Formally Mini_Uk London |
29th Sep, 2008 at 10:25:24pm
I have to change my manifold Gasket. I've got the carb and inlet manifold off. now have to take the outlet along with the turbo.
Shit Happen's |
29th Sep, 2008 at 10:30:00pm
Do it right -take the exhaust/turbo etc off completely.Its always worse thinking about it than doing it.Oops,what did I just say ?. |
29th Sep, 2008 at 10:54:08pm
On 29th Sep, 2008 tadge44 said:
Do it right -take the exhaust/turbo etc off completely.Its always worse thinking about it than doing it.Oops,what did I just say ?. But surley i could puch the manifold/ turbo back allowing 5mm to slip the Gasket on ? Who else has done this.. Cheers :) Shit Happen's |
29th Sep, 2008 at 11:01:04pm
try it and see, if you start to strain anything, bite the bullet and remove it as needs be "Turbo's make torque, and torque makes fun"
29th Sep, 2008 at 11:26:11pm
Any good tips then please Shit Happen's |
30th Sep, 2008 at 05:48:59am
You need to get a lot more than 5mm, as you have to clear the manifold studs.I have often done it on N/A Minis but I would not try on a turbo,even with the extra time involved |
30th Sep, 2008 at 07:44:02am
As above, unless all the studs came out with the nuts, the manifold has to go a long way back to clear the studs. You can't rock it to help because the outer studs are through holes, not slots, and the turbo manifold flange is thicker than standard. (I'm assuming this is Metro T3 stuff)
30th Sep, 2008 at 11:48:06am
i had to change the head gasket at combe, we undid the stabilizers and rocked the engine off the intake and exhaust manifold and lifted the head off, it was easier that i imagined it would have been, took us an hour and a half to change it and put it back together. I do have a flip front though which may make it a bit easier. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
30th Sep, 2008 at 01:41:43pm
Ive always left the turbo connected to the drain as its a PITA to put back on.
30th Sep, 2008 at 03:13:47pm
i've put caphead bolts in now to make it really easy |
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
30th Sep, 2008 at 03:20:50pm
or use a late injection gasket, as they also have fire rings in them!! but are about £4 not £20 as the turbo ones are...... "Cars are a lifetime of pain" |
1st Oct, 2008 at 11:46:03am
turbo ones are only about £6ish |
1st Oct, 2008 at 12:52:13pm
I dont even take the turbo out when I remove the head anymore. I use my low lift jack to lower it on the down pipe to give me clearance the only knuckle bender is the oil feed and return lines. Own the day
1st Oct, 2008 at 01:29:47pm
I've never removed the turbo to get the head off.
In the 13's at last!.. Just |
1st Oct, 2008 at 03:51:11pm
On 1st Oct, 2008 iain said: There are 3 differnt types I have come across and the prices do vary some what but £20 sounds way to high
turbo ones are only about £6ish Own the day
1st Oct, 2008 at 08:43:54pm
jsut had a wee brain wave, to save soem time. undo all the nuts and slide everythhing back so you can access the gasket but not so far back everything is off the studs, tear the old gasket off, and "slot" the stud holes in teh new gasket on one side, drop the gasket in and do everything back up :) turbo 16v k-series 11.9@118.9 :)
2nd Oct, 2008 at 03:46:21am
Can anyone see a downside to this,please ?. |
2nd Oct, 2008 at 06:55:11am
as said undo the nuts undo the stablisers then tilt engine forward, its a piece of piss to do and yes the injection gaskets are buy far the best for any engine. always looking for them bigger bunches of bannanas |
2nd Oct, 2008 at 11:46:46pm
I Got the injection gasket as rich says, which arrived today from minispares.
Shit Happen's |
3rd Oct, 2008 at 11:26:08am
As stated before support the exhaust with your troley jack Own the day
