| Home > Help Needed / General Tech Chat > Cars running perfect again! | |||||||
25th Aug, 2004 at 10:48:34am
Hi, cars running perfect now with a nwe fuel regulator. With the old one, the pump whined and the pressure was constantly on/off. I can now boot it! Its awsome! Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
25th Aug, 2004 at 10:49:05am
by the way. the reason for needing a new one is my old one is split and cracked Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
25th Aug, 2004 at 12:42:07pm
all the pipes are pretty much the same... compare prices and decide.
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
25th Aug, 2004 at 01:50:36pm
I have the ManiFlow ... or is it maxiflow downpipe from avonbar
TurboLessTosser |
244 Posts Member #: 34 Senior Member |
25th Aug, 2004 at 01:55:38pm
I got the maniflow down pipe, and I did need to mod the clamp.
25th Aug, 2004 at 02:06:16pm
Gibbo how did you mod it ;; I mean what did you have to do ?
TurboLessTosser |
25th Aug, 2004 at 02:17:11pm
Needs a picture really...
25th Aug, 2004 at 03:28:37pm
As TD said. But if you've got the pieces off the car, then its quite easy to see what needs to be done.
25th Aug, 2004 at 05:12:54pm
If you cant weld them you can use a two bolt locking tab like the one off the diff housing... works great
25th Aug, 2004 at 10:11:31pm
I've bought two downpipes over the years fron Ian at avonbar and i am pretty sure they were both Maniflow items. On 21st Jan, 2011 fastcarl said:
63 Posts Member #: 325 Advanced Member |
25th Aug, 2004 at 10:27:00pm
I use the green maniflow downpipe from minispeed. It is the pipe with the ball pivot and tension spring.
Edited by killer_chiller on 25th Aug, 2004. |
