| Home > Help Needed / General Tech Chat > Turbo Timer | |||||||
24 Posts Member #: 268 Member |
25th Aug, 2004 at 12:49:28pm
I aint too clued up, but will the mini need to be running the metro turbo ECU to wire up a turbo timer, and also a boost controller?
25th Aug, 2004 at 05:15:47pm
Think you can run a timer on any engine with or without ecu
30th Aug, 2004 at 04:58:21pm
thanks for the help, but what are MBC's?
31st Aug, 2004 at 06:01:17pm
they are boost pressure valves that are used to regulate the boost pressure that the actuator sees
4th Sep, 2004 at 03:01:32pm
cheers champ
