Home > Help Needed / General Tech Chat > eleven stud drilling?
welshdan
Member #: 1111
s wales
hi, i will be drilling and tapping the block to take an 11 stud head. what depth can i go over the water pump end? is this depth measured from the tip of the drill bit or the full thickness of the bit?
also, what depth can i drill to at the flywheel end? many thanks
On 8th Dec, 2006 BENROSS said:
oh! like to add drill the thermostat side no more than 12.5 mm & tap
saves breaking in to the water pump gallery in the block
number 4 side the same depth as the others, i think 15 mm but please check
and then tap
torque up the two end ones 30 foot pounds no more
some peeps torque up number 4 side the same as the rest but i dont
each to there own
welshdan
Member #: 1111
s wales
is the 12.5mm from the tip or the full width of the drill?thanks
dont go depper than 12.5mm or else!!
It doesn't matter that much if you break through anyway, as long as the stud is sealed correctly.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Why would you want to do this? I have run 14:1 cr and not needed the extra bolts.
Is this a worthy mod when going to huge over bores ie 1380 and 1440cc etc etc etc?
Own the day
