Home > Help Needed / General Tech Chat > URGENT - Help with Quaife ATB LSD Spacer and Preload
pristic
Member #: 1774
Sydney AUS
Hi Guys,
Need help urgently.
Does anyone have a quaife ATB LSD not installed... I need to know the size, width, etc of the spacer that keeps the bearing spaced away.
1/8" or something I think.
Swiftune sent 10 quaife ATB LSD's to a supplier here in aus and none have the spacer :(
Please help!
Also - does anyone have instructions on setting the preload, etc on the diff? Should it be right out of the box or anything?
Thanks
Peter
1132cc Turbo ~120 bananas ATW - Fun Fun Fun
spacer??
Do it as per the haynes manual (as std), but shim it on the opposite side
pristic
Member #: 1774
Sydney AUS
Ok, supplier just spoke to Swiftune - no more spacers! Yay - first production run had to have spacer as machining was not exact (or something)
Ok, forget the spacer - literrally just got the call from supplier.
No, how about diff preload? Do you have to set it or anything?
Thanks,
Peter
i cant remember the settings and I dont have my book to hand about the shims for the preload
Interesting what you say about the spacer as mine too loads of shims to get it right
Edited by Nic on 3rd Oct, 2008.
pristic
Member #: 1774
Sydney AUS
Thanks guys,
Nic, did you get the first batch of the quaifes?
I was told by my supplier - who just spoke to Swiftune after I panicked about the spacer that the first batch had too much machined off the diff and it needed a spacer to ensure the bearing sat right.
The spacer goes on the opposite side of the crownwheel ... so if yours is shimmed up there then that could be the cause.
Either way, I was excited to get cracking and the quaife is so bling that I thought surely it needs some tweaking :) I am glad it doesnt, ill just whack it in and off we go!
The new hybrid turbo will be ready next week, orange clutch and race/rally ex heavy duty clutch plate is ready too..
Yipee!
Pete
could you take a measurement across the diff so I can check mine?
Its deffo an early one, but i dont know if its on of the first batch, i remember it being a bit funny
Before anyone else mentions it-ill remind you to tighten up your ball joints before taking the car out....
pristic
Member #: 1774
Sydney AUS
lol, and your wheel nuts - mine hit the ground in a corner - oh how embarresment :)
lll take measurements for you but wont be able to get them for a couple days - literally just dropped the diff off at the shop and am FLAT stick this weekend (the Wife wont let me go and play right now :(
Ill post up pics and also the measurements for ya *wink*
Pete.
cool,
this is the first i've heard of the early ones being different,
Hopful;ly this will help people in the future.:)
pristic
Member #: 1774
Sydney AUS
When you put in your quaife diffs - did you just leave the diff as it was shipped ?
Is there ANYTHING on the diff itself that needs adjusting, etc. The diff's preload or anything? or is it a matter of throw on crown wheel, and get the thing in - shims etc as normal?
Ill get pics and measurements of my diff on Wed now - thats when intsall is as turbo not finished...
Pete
Yep, just bolt up the crown wheel, put the shims on the opposite side when you bolt it all together and off you go
pristic
Member #: 1774
Sydney AUS
Thanks Nic - sweet - that makes me very happy lol
Will post pics n 2 days... woohoo!
