| Home > Technical Chat > Question about that wet stuff .... Water | |||||||
Site Admin ![]() 9407 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
3rd Oct, 2008 at 12:46:01pm
Does water absorb heat at the same rate that it disperses it? On 15th May, 2009 TurboDave said:
3rd Oct, 2008 at 12:53:10pm
i thnik it abosorbs it quicker, may be wrong but it rings a bell. On 28th Aug, 2011 Kean said:
3rd Oct, 2008 at 02:45:20pm
Heat transfer is a question of temperature difference. The larger the temperature difference, the faster the heat will transfer.
3rd Oct, 2008 at 03:02:33pm
surely the material also has a bearing, alloy heat sinks and all that
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
3rd Oct, 2008 at 04:12:50pm
Look at "specific heat capacity" on wikipedia.
Bugger off, I'm getting there. |
3rd Oct, 2008 at 07:02:32pm
On 3rd Oct, 2008 jbelanger said:
Heat transfer is a question of temperature difference. The larger the temperature difference, the faster the heat will transfer. Jean
Yes i moved to the darkside |
4th Oct, 2008 at 08:59:19am
yes all to do with specific heat capacity.
6th Oct, 2008 at 02:47:41pm
Correctamundo. Bugger off, I'm getting there. |
2497 Posts Member #: 1954 Post Whore Luton Bedfordshire |
7th Oct, 2008 at 01:07:42pm
It also depends on the state of the water, fog, spray mist or slug. The greater the surface area available for heat transfer the faster heat will be transfered/dissapated. Own the day
7th Oct, 2008 at 09:13:43pm
2 interesting equations relating to heat exchange.
7th Oct, 2008 at 10:43:59pm
Not to mention that volume to surface area ratio also affects heat transfer rates Own the day
8th Oct, 2008 at 12:30:06am
Heat transfer rates are irrelevant, unless you divide the whole lot by time.
8th Oct, 2008 at 08:49:27am
Apart from the issues of heat transfer, cooler efficiency etc, the answer is yes provided the conditions that affect heat transfer are the same on the heating and cooling.
8th Oct, 2008 at 10:11:47am
And you can make it even more complicated if you operate the "heat exchanger" at close to boiling point, or more specifically if the material of the heat exchanger (the heat source) is above the boiling point for the water's operating pressure. Schrödinger's cat - so which one am I ??? |
8th Oct, 2008 at 01:56:57pm
Ah but there is a very exoyic and simple method of extracting heat from a fluid. If you send the fluid through a coupled turbine/impellor then a heat exchager then out through the identical turbine the energy put into said fluid by the first turbine will be extracted by the second less that removed by the heat exchanger. This principle is used on the airconditioning units on planes, I wonder if it can be used on a liquid? Own the day
8th Oct, 2008 at 02:37:26pm
ok, thanks for your thougths, I've been able to follow some of them. My Reason for the question is I'm tyring to work out if in theory you have an engine with electric water pump, how do work out the optimal speed for the water to flow the the rad. There must be a speed which is too fast, and two slow?
8th Oct, 2008 at 02:53:34pm
This thread may help:
8th Oct, 2008 at 11:35:04pm
On 3rd Oct, 2008 mini13 said:
i thnik it abosorbs it quicker, may be wrong but it rings a bell. id say so, otherwise how does a kettle ever boil? "Turbo's make torque, and torque makes fun"
9th Oct, 2008 at 11:56:49pm
i thnik it abosorbs it quicker, may be wrong but it rings a bell. id say so, otherwise how does a kettle ever boil? heat is energy, energy travels from the hottest thing, to the coldest thing. the larger the difference in temperature between the hot thing and the cold thing, the faster the transfer... with me? a kettle boils because the heating element is putting more energy into the water than it can get rid of over its meager surface area for a given unit of time. :) this is largely helped by the fact that the metal eliment is in contact with the water, and metal - liquid results in a good heat transfer coupling. the water is in contact with air, which by comparrison is a good insulator! so the water cant shed its new found energy to the surrounding air anywhere near as fast as the eliment can shove energy into the water. if the air was at several 100 degree's, and the water was in a metal basin maintained at 20 odd degrees it wouldnt boil. Edited by evolotion on 10th Oct, 2008. turbo 16v k-series 11.9@118.9 :)
444 Posts Member #: 2885 Senior Member |
10th Oct, 2008 at 12:22:05am
i water cool my graphics cards in my pc and ive been told to add something called water-wetter which basically lowers the surface tension of water so that more of it is in contact with the metals that conduct heat to and from the water (water block and rad)
or something . ha
