| Home > Beginners Tech > buying advice | |||||||
286 Posts Member #: 4008 Senior Member near cardiff np12 |
4th Oct, 2008 at 04:59:37pm
im looking to buy a few things for my clubby not sure whats the best things to get
4th Oct, 2008 at 05:09:00pm
For general "what can a do to make it go quicker?" questions, you can't beat turbo phils site:
On 7th Nov, 2008 Nic said:
4th Oct, 2008 at 06:46:00pm
On 4th Oct, 2008 Jay#2 said:
For general "what can a do to make it go quicker?" questions, you can't beat turbo phils site: http://www.turbo-mini.com/index2.html Thank you sir !
As for fitting a bleed valve i wouldn't advise fitting one & just turning up the boost until you know a little more about your engine. Compression, ignition timing & fuelling all need to be considered. |
4th Oct, 2008 at 08:16:20pm
spoke to my cousin who owned the engine before it was fittied to the car
4th Oct, 2008 at 08:21:15pm
you need to try and find out the engine specs such as what the compression ratio is, what cam its running, what timing is, what pistons and if its been setup on a rolling road before.
4th Oct, 2008 at 08:23:19pm
As Mr Phil says it would be useful to know what compression ratio you have, then you will know for sure what you can do. Again check out turbo phils site:
4th Oct, 2008 at 08:40:55pm
will try and find out more
