Home > Help Needed / General Tech Chat > actuator- cut threaded bar?
mayoturbo
Member #: 1395
chepstow
Do i need to cut the bar down on the avonbar actuator? It wont wind down into the arm that much
thanks
Ul have to pull the arm on, the shorter the arm the more boost, if the arm just slips over it will run nearly zero boost.
Rick
Edited by cossierick on 5th Oct, 2008.
chinlesswonder
Member #: 1192
In the garage......again!!
yeh, ihad the same problem, just cut it down to roughly the same length as the standard actuator
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
mayoturbo
Member #: 1395
chepstow
ok thought Id check before cuting anything
chinlesswonder
Member #: 1192
not too much preload on those actuators either otherwise the boost will be sky high 1mm should be ok for standard pressure if its the 10psi one.
