| Home > Help Needed / General Tech Chat > Injection fuel tank | |||||||
63 Posts Member #: 325 Advanced Member |
26th Aug, 2004 at 05:40:55pm
Can you use an injection fuel tank with the metro turbo fuel pump mounted externally from the tank, or do you have to use the injection fuel pump? |
126 Posts Member #: 244 Advanced Member |
26th Aug, 2004 at 05:55:10pm
no need for metty turbo pump as well as Injection tank unless you are planning huge boost.
Speedster turbo under construction |
26th Aug, 2004 at 07:36:23pm
What boost are you running? |
27th Aug, 2004 at 01:14:53am
standard boost (6psi) You will find alot of cars on here use the injection tank. From what I recall, only the big boys (12psi and up) use external pumps. Might be wrong though, hopefully Turbo Dave or Miniwilliams will put me straight. Speedster turbo under construction |
27th Aug, 2004 at 09:34:00am
I am running 9psi but my engine is built to take upto 15psi so I guess I should really stick with the metro turbo fuel pump, just incase 9psi becomes a yawn!
195 Posts Member #: 26 Advanced Member Cannock |
27th Aug, 2004 at 01:02:13pm
YES it is built into the tank, the question is which injection tank are you after mpi or spi? |
27th Aug, 2004 at 03:54:48pm
Is there a difference?
27th Aug, 2004 at 04:34:19pm
if you dont use the pump from one, let me know ill buy it from you Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
27th Aug, 2004 at 10:01:18pm
there is no need to use the pipework from a mini, I went to B&Q and bought a 20meter roll of 8mm microbore copper pipe for my fuel lines. cost me about £12 I think.
28th Aug, 2004 at 10:59:31am
When using the standard 7.5 gallon tank, has anyone had to enlarge the main fuel feed pipe?
Edited by killer_chiller on 28th Aug, 2004. |
29th Aug, 2004 at 06:54:27pm
Modded the standard 7.5 gallon fuel feed pipe in the end. I just chopped it off and welded a 12mm pipe on.
