| Home > Help Needed / General Tech Chat > Fitting an mpi fuel tank to my 1380 n/a | |||||||
6th Oct, 2008 at 11:43:00am
I wanted to know if this was worth it. if so how does the plumbing work? Edited by philc on 6th Oct, 2008. |
6th Oct, 2008 at 11:50:14am
simple fit and the neatest option. basically just has a feed and return line back and forwards to the regulator. |
6th Oct, 2008 at 03:31:04pm
for what i have been told today, these run at around 3bar, too much for mine though great for turbos |
6th Oct, 2008 at 03:32:28pm
On 6th Oct, 2008 philc said:
for what i have been told today, these run at around 3bar, too much for mine though great for turbos Only if your regulator holds it at 3 bar. It will be fine at any lower pressure. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
6th Oct, 2008 at 03:39:52pm
i only need around 3psi, would a regular hold it at that?? |
6th Oct, 2008 at 03:47:16pm
i only need around 3psi, would a regular hold it at that?? Yep, I've used a 3 bar pump and a standard metro turbo regulator at 3 psi, no problem. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
6th Oct, 2008 at 03:57:29pm
don't i need a return supply to the pump, bearing in mind mine is a n/a engine Edited by philc on 6th Oct, 2008. |
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
6th Oct, 2008 at 03:58:38pm
yes |
6th Oct, 2008 at 04:05:55pm
all of them need a return line with HP systems.
6th Oct, 2008 at 04:31:57pm
mpi tank no good for me then. thanks |
7th Oct, 2008 at 06:26:03pm
would i be able to use an spi tank instead and by pass the fuel pump and use an external pump and would i need a return feed?
