| Home > Help Needed / General Tech Chat > can i run oil return into oil filter housing.. sidemount turbo... | |||||||
40 Posts Member #: 3490 Member new zealand. land of the kiwi bird |
8th Oct, 2008 at 06:48:25am
as per title. its a side mounted turbo. can i run the return into the oil filter housing if i tap and thread a fitting of some kind... |
8th Oct, 2008 at 07:28:24am
I wouldn't, due to the pressure the oil is coming out o the pump & the restriction caused by the oil filter I would have thought all you'd do is pressurise the oil return coming from the turbo reducing the flow of oil through the turbo. Isambard Kingdom Brunel said:
8th Oct, 2008 at 07:59:03am
Easiest way is to put the return into the breather hole above the drop gears. http://www.twin-turbo.co.uk
8th Oct, 2008 at 11:19:20am
best place ben
