| Home > General Chat > wheel bearings Tip // trick inside | |||||||
9th Oct, 2008 at 05:46:26pm
which way do wheel bearings go arround? so the bearings fall freely out?
Edited by Paul R on 9th Oct, 2008. Drives
9th Oct, 2008 at 05:52:42pm
Yes,
9th Oct, 2008 at 05:54:20pm
fronts, i got the hub in the oven and the bearing rings in the freezer atm lol :)does the seal with the extra plastic seal go front or back i cant remember Drives
9th Oct, 2008 at 05:59:11pm
That seal goes to the back (engine side)
9th Oct, 2008 at 06:01:23pm
yeah i know i probably will have to just wanted to get the first bit started :)
9th Oct, 2008 at 07:22:37pm
i would not bother with the heat and freezer
9th Oct, 2008 at 07:37:16pm
As above, punch or a drift to knock out. A socket to fit new ones. Nice light taps. On 19th Jan, 2010 wil_h said:
9th Oct, 2008 at 07:38:47pm
dont have a socket big enough to tap it in with, thats the only proplem and why i did it the way i did. was thinking about carving up some wood to use but not sure if it will work Drives
9th Oct, 2008 at 07:38:50pm
9th Oct, 2008 at 08:50:51pm
That would work, problably better as its nice and soft. It won't do any damage to the bearing. On 19th Jan, 2010 wil_h said:
9th Oct, 2008 at 08:56:44pm
ally bearing push kit. great tool! |
9th Oct, 2008 at 08:58:12pm
i use an old race with the od ground down a midge and tap it home square with that "Turbo's make torque, and torque makes fun"
444 Posts Member #: 2885 Senior Member |
10th Oct, 2008 at 12:05:57am
i turned a bit of alu. to 'abit smaller than race dims.' and used it as a drift.
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
10th Oct, 2008 at 09:29:41am
yes thats very true. 2 sets of wheel bearings in 2 months on a standard road going mini. i then decided to use a big socket and theyre still ok after 6 months On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
![]() 82 Posts Member #: 2675 Advanced Member Isle of Man |
10th Oct, 2008 at 02:42:43pm
I recently replaced the front wheel bearings on my project car and found using the haynes manual and it's diagrams along with this youtube clip really helpful for a first time wheel bearing job.
"If i'm not in action...i'm in traction" |
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
10th Oct, 2008 at 03:45:10pm
my wheel bearings are a bit dodgy, i bet i've not got my ring in square lol
250 Posts Member #: 1615 Senior Member Ferndown, Dorset |
10th Oct, 2008 at 05:20:26pm
had had someone get me to look at there car due a funny noise, turned out the wheel bearing had gone bigtime, when i told him he said he had done it a week ago, i then proceeded to undo the hub nut by hand, he had used mole grips to do it up!
On 1st Mar, 2009 MikeRace said:
Hmmm weberyyy On 21st Apr, 2009 madcatminis said:
I hope she's got knickers on or you'll have a funny runny mark on your bonnet. Quite like what a snail leaves behind. |
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
11th Oct, 2008 at 02:27:56am
On 10th Oct, 2008 clubminiflip said:
i bet i've not got my ring in square lol small taps and lube!! ![]()
