| Home > Help Needed / General Tech Chat > No camshaft end float (pics) | |||||||
152 Posts Member #: 2190 Advanced Member South Carolina, USA |
11th Oct, 2008 at 08:20:17pm
I can’t move forward anywhere! I just finished posting my issue with the idler gear…still trying to figure out what to do with that… so I decided to work on the other side on the engine.
Edited by Mikes1098 on 18th Oct, 2008. |
11th Oct, 2008 at 09:20:13pm
Just measured a couple of used ones - about 093-094.
Edited by Rod S on 12th Oct, 2008. Schrödinger's cat - so which one am I ??? |
18th Oct, 2008 at 03:24:48am
Wanted to update this post with what I found, just in case it will help someone else…
18th Oct, 2008 at 04:08:33am
On 11th Oct, 2008 Rod S said:
Just measured a couple of used ones - about 093-094. This implies the shoulder on the gear should be about 1.000 as your new one would then give minimum (but acceptable) clearance. I have heard of people machining back the raised boss on the back of the gear instead of putting a new thrust plate in - possibly this has happened in your case ??? If so, you could make a shim (I doubt anyone sells them) BUT... if you try to thin down the thrust plate instead, make sure you thin down the steel side, not the bearing side. EDIT - I'll repeat the last sentence "if you try to thin down the thrust plate instead, make sure you thin down the steel side, not the bearing side." I've just seen posts on the other two "main" forums from someone in the States who was told on one forum that they have a bearing surface, didn't like the answer, so has posted on the other one trying to get someone to say different. Maybe, just maybe, some copies you are getting in the USA aren't being made properly ??? They should have whitemetal on the side facing the cam and you shouldn't be able to put them on backwards as the three sides of the triangle are all different lengths. Where else other than Turbo Minis would you get an answer like that :) Well done that man :) On 26th Oct, 2004 TurboDave16v said:
18th Oct, 2008 at 07:50:44am
Thanks Sprocket - in fairness I had just been doing my own one a few days earlier so it was all fresh in my mind, and I had to ask the forum about another bit of it
Edited by Rod S on 18th Oct, 2008. Schrödinger's cat - so which one am I ??? |
18th Oct, 2008 at 03:14:38pm
Yeah, I ordered a couple extra shims, figuring that I would have to get the crank gear out a bit.
