Home > General Chat > support panel at the window corner
akirch
Member #: 399
Austria
Hello,
I am playing with the idea to leave these parts away at my actual project:
I think, they are only good for rusting, when dirt and water gets behind them. I want to seal the hole to the engine bay.
The only thing i keep in mind is the stability. *oh well*
What do you think?
Regards, Andreas
http://www.minifreunde.at
do you mean you want to get rid of the fresh air vent?
If you dont fit the scuttle closing panel, water will get into the engine bay, as well as starting the A post rotting, which is not a fun job.
Fit the closing panel, and make sure you seal it really well, and then spray Waxoil or similar into the cavity, from the engine bay.
akirch
Member #: 399
Austria
No, i want to stay it like this:
(without the support panels)
akirch
Member #: 399
Austria
OK - i will take the correct way, thanks Sprocket!
as sprocket points out, if you leave the closer panel off, this opens up the door post at high level and will rot out far quicker.
barkiboi
Member #: 591
Rugeley, Midlands, England
I knocked some up when cutting my front end off and sealed up the corners with some metal type putty and lots of spray paint done the job no rust.
