Home > Technical Chat > Transfer gear noise
MrTurbo
Member #: 814
Utrecht, The Netherlands
I finally finished my my turbo mini this weekend and got an MOT one hour ago! Pictures of the build will follow this weekend.
The car drives really well, though only on 9 psi for the time being (awaiting RR session).
Thanks Benross for the excellent work on the head!
I do have one short question: the timken SC transfer gears make quite a bit of noise when the car is in neutral and the clutch disengaged. When I engage the clutch or drive the car the ratteling noise dissapears. Is this normal for the S/C timken setup?
Thanks!
Yes
Mines the same, asked this question recently, apparently its the noise all sc drops make.
MrTurbo
Member #: 814
Thanks for the quick replies! I will start tuning the car this weekend. I'll send updates on the progress.
Hedgemonkey
Member #: 360
SC gears have a fair bit of lash in them and whaat you're hearing is the pulsing of the engine and the lack of pulsing of the gears causing them to go clack clack clack chatter chatter.
Turbo Tel
Member #: 588
Delaware, USA
And when you drop the clutch they stop spinning so the noise stops.
hario
Member #: 2885
I read somewhere on here someone used the transfer case vent as an oil return i think with their sidse mounteeed turbo but could maybe be used with a normal position turbo to quieten the drops ?!
Ben H
Member #: 184
Melton Mowbray, Pie Country
It is too high for turbos mounted in the conventional way.
http://www.twin-turbo.co.uk
