| Home > Technical Chat > Clutch backplate lugs / straps / etc. setup / build | |||||||
15th Oct, 2008 at 03:40:09pm
I built up my clutch assembly today in the correct manner (as per TM) of machining the backplate lugs.
Edited by Rod S on 15th Oct, 2008. Schrödinger's cat - so which one am I ??? |
15th Oct, 2008 at 07:27:16pm
erm,
15th Oct, 2008 at 07:36:31pm
Joe
On 15th Oct, 2008 Rod S said:
So then I went to measure up the spacers I'll need under the straps to flywheel (it's a lightened one so thinner) In the 13's at last!.. Just |
15th Oct, 2008 at 07:39:29pm
Edited by Joe C on 15th Oct, 2008. On 28th Aug, 2011 Kean said:
15th Oct, 2008 at 07:39:58pm
Yes it is, but I don't have a problem with that....
15th Oct, 2008 at 07:44:56pm
well any thread sticking out the back can just be cut off, but somthing does seem amiss, ive not noticed this issue on lightenend flywheels.
15th Oct, 2008 at 08:26:07pm
I think you're worrying too much. The spacers have been used succesfully by many for many years.
Edited by turbodave16v on 15th Oct, 2008. On 17th Nov, 2014 Tom Fenton said:
16th Oct, 2008 at 09:31:04am
Yep, I worry too much Schrödinger's cat - so which one am I ??? |
16th Oct, 2008 at 10:53:17am
Are you using the shorter bolts into the flywheel, and the longer bolts into the pressure plate? On my steel flywheel, the bolts only just come to the bottom of the hole on the flywheel and may protrude by about 1 thread, no more On 26th Oct, 2004 TurboDave16v said:
16th Oct, 2008 at 11:46:10am
On 16th Oct, 2008 Sprocket said:
Are you using the shorter bolts into the flywheel, and the longer bolts into the pressure plate? Yes, the difference is length is quite significant so hard to get wrong :) I think it's just because machining the lugs on the backplate means the diaphragm cover and straps go closer to the engine - the backplate stays where it is because of the fixed thickness of the driven plate (but maybe also the AP plate is thinner than a standard one ???) - so the spacers have to be "relatively" thinner than if the lugs hadn't been machined which puts the bolts "relatively" further into the flywheel. Also I wasn't intending to use the locktabs which again adds to the distance they go through. Now assembled with locktabs (not really for locking, just as packing to pull the bolt out a bit) I get 2.5mm clearance and visually the bolt only protrudes about 1-2 threads. Interestingly, the "standard" spacers - I dismantled an old scrap flywhel to get the straps and bolts - are only 1.83mm thick washers so If I had used a standard flywheel and machined my 1.6mm off the backplate lugs, I would have needed spacers 0.23mm thick !!! Thus the straps would be virtually touching a standard flywheel and the clutch might not have been able to release ??? Anyway, it looks fine now..
Spacers are 8.6mm thick to get straps parallel on this flywheel with 1.6mm off the backplate lugs. Schrödinger's cat - so which one am I ??? |
16th Oct, 2008 at 10:17:42pm
the atraps do not hve to be paralle to the flywheel, somewhere near wiil work just fine,
17th Oct, 2008 at 07:50:41am
Agreed, they're not going to stay parallel anyway, as the driven plate wears.
20th Oct, 2008 at 08:06:52pm
that pic is of my rear clutch, i was mighty pissd off when that happened seing as i'd only fitted them as new that season, on removal i found them to be made of toffee, not heat treated as they should have been,
