| Home > Help Needed / General Tech Chat > Cylinder Head! | |||||||
![]() 2 Posts Member #: 3195 Junior Member Huddersfield West Yorkshire |
15th Oct, 2008 at 10:00:15pm
Hi there,
Era Mini Turbox2
15th Oct, 2008 at 11:03:38pm
Ricky , am sure one of the main mini engine builders would be able to help with the stem seals or id ring rich at minispares?
15th Oct, 2008 at 11:10:25pm
I have the Turbo valve guides in stock, i wouldn't use the stem seals on the exhaust personally. :)
16th Oct, 2008 at 09:14:18am
Disconnect the boost hoses to see if it's the turbo or not.
In the 13's at last!.. Just |
16th Oct, 2008 at 09:38:17am
As Phil says, seals on the exhaust guides are not needed.
16th Oct, 2008 at 02:57:41pm
Why not use the ones you've got, and fit some K-line inserts. I'd do that if I had 8mm stems. On 13th Jul, 2012 Ben H said:
17th Oct, 2008 at 09:16:30pm
Thanks =) Checked turbo today, looks fine! Thinking about getting an unleaded head! Era Mini Turbox2
