| Home > Beginners Tech > verto/non verto clutch on turbo mini | |||||||
16th Oct, 2008 at 11:49:21am
what do most people run? verto or non verto? i understand that you cant fit uprated diaphragm to the non verto setup. hopefully will be running about 120 bhp, so was thinking that i need to go for non verto? is this right? many thanks |
16th Oct, 2008 at 01:26:39pm
Non Verto the majority of the weight is biased toward the centre of the assembly. Verto the weight is biased towards the outer edge of the assembly. This means for rev happy people fit the non verto type.
Own the day
16th Oct, 2008 at 06:27:21pm
Any real increase in torque over the standard 85 ft/lb & the Verto just won't hold.
16th Oct, 2008 at 10:29:50pm
iv got the ap clutch plate. but minispares said that the only diaphragm for non verto is standard. so am i looking at verto or non verto? |
16th Oct, 2008 at 10:45:02pm
On 16th Oct, 2008 welshdan said:
iv got the ap clutch plate. but minispares said that the only diaphragm for non verto is standard. so am i looking at verto or non verto? They must have got mixed up. There are several diaphragms for pre verto. Green, Blue, Orange, Grey and Double Grey if memory serves On 12th Nov, 2009 Paul S said:
Gary's description is best |
16th Oct, 2008 at 11:43:43pm
the vertro wont hold up ..Period!
16th Oct, 2008 at 11:56:47pm
Lets add a third option; double verto Isambard Kingdom Brunel said:
17th Oct, 2008 at 01:06:59am
17th Oct, 2008 at 01:49:29pm
I'd go for a double verto setup, as per Roberts thread (in tech section). His seems to withstand his "get away car" driving style with quite a few bananas and curleys on board. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
17th Oct, 2008 at 07:26:05pm
so i need long arm- pre verto? cheers |
17th Oct, 2008 at 07:52:09pm
It can get a little expensive to convert to pre-verto from verto.
17th Oct, 2008 at 08:15:01pm
what kind of cost is involved? i have both verto and non verto setups on some of the spare engines i have. do you mean initially getting hold of the parts, or am i overlooking another cost? ta |
17th Oct, 2008 at 08:32:20pm
If you have pre-verto parts then it will be best to use them.
18th Oct, 2008 at 12:02:53pm
try this instead, weld the verto and pre verto together!
18th Oct, 2008 at 12:06:05pm
iv got the ap clutch plate. but minispares said that the only diaphragm for non verto is standard. so am i looking at verto or non verto? Who said that? |
18th Oct, 2008 at 06:48:20pm
not sure. not sure what minispares branch it was. said that verto diaphragm was standard. so my brother had to put a standard one back in his 1380 |
