Home > Help Needed / General Tech Chat > Front Subframe lightening
Scruffy
Member #: 328
Seaford Rise, South Australia
Q1 Any idea how much a bare single bolt one weighs?
Q2 How much weight could I take out of one and the car still go around corners without it flexing?
Ta muchly
On 5th Sep, 2011 Vegard said:
Ebay link to a pic
another thread
best info is in the second link matey*happy*
i'm sure i weighed one year ago, and it was 38lbs,
i would not be too worried about flex if you were me,
they are not very stiff when not in car , but once buttoned up as you will know are much better,
if you cannot get 3 kgs easily out i'd be surprised,
carl
Si P
Member #: 912
North Yorkshire
You can take a lot of weight out of them. I did it with mine. Hard work mine you. Also depends if your running coilovers on the front, to where and how much you remove.
Si
who did the ebay one ? is it someone on here ?
Is that Gavin's or Pauls?
t3gav
Member #: 229
Gavin@minispares.com
kent
I've seen 2 standard front subframes in the last 2 weeks that have cracked right across the middle at the front.
I've seen that a few times too, isn't that because there top engine steady's a shagged, so the bottom one is taking all the abuse, and so stressing the front of the subframe?
t3gav
Member #: 229
kent
Yeah could be, I'd always fit 3 steadies as a minimum anyway.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
That one on ebay looks very light perfect for an 850...
put a turbo in there and I think you'll be in trouble very quickly!
AlexF
it looks like some dodgy subframe shaped cheese to me*happy*
id leave mine as it is or build / buy a tubular one*smiley*
Scruffy
Member #: 328
Thanks Guys
